Old 03-14-2010, 08:40 PM
adam_m is on a distinguished road
Newbie - looking for some guidance... 8020
First post, "Hello"...
I've seen a lot of different designs and am curious about the 8020 setups that I've been seeing. I downloaded a pic of a table that looked interesting and wanted to ask some questions about it to the forum, hopefully the owner can chime in. (sorry for not remembering the link)
It appears that there are already custom parts that are made to order for building a CNC out of 8020, does anyone have a link to that site(s)?
What kind of performance/accuracy are you getting from the build?
In the pic I attached it appears the builder is using ACME rod but what type of linear bearings? all that I see are UMHW type do they make anything different? are they really that good as opposed to a roller type?
The steppers are mounted on brackets I assume these are manufactured as well?
Why the need for the multiple 8020's banded together - does it flex too much? does it really not make a good CNC setup?
I'm reading as much as possible but there is so much to learn for a neewbie.. hopefully you guys can help me out.
AJM,
Old 03-14-2010, 09:25 PM
ben_jackson is on a distinguished road
I'm working on a design for a similar router right now and I have some notes for a "build thread" post including these references, which you will find useful:
Ahren's R&P development
jsanto's 8x5' build
Arbo's 24x80" build
lunchtrayrider's small but scalable build
Joe's 4x4 Hybrid megathread where it discusses R&P
The pic you included appears in one of those threads.
At 8020.net you can download a deflection calculator. I think most people are overbuilding their 8020 routers. A length of 3030 (3" square) is about the same weight as .120 (nearly 1/8") wall steel tube in the same size, and significantly stiffer. However, overbuilding is always a fine policy with the possible exception of the gantry, which can easily weigh upwards of 150lbs in a 5' wide design. A 5' length of 3060 weighs 40lbs and the 7" steel plate on the front weighs 30lbs. Cutting back to 3030 and 4" plate cuts the weight to about 40lbs total. Unfortunately no one has done the FEA on the 3030+plate combo to really know what the deflections would look like under various loads, whereas the 3060 alone is definitely good for only a few thou deflection.
One other motivating factor for not overbuilding with 8020 is that it's pretty spendy. My design puts a flat 8020 table on a steel frame. The frame will be about $200 in locally-available tube steel and the 8020 in the router is over $1000.
(working design shown below with all-3060 gantry which will be reduced at least to 1545 sides...)
Name:	CNC Router - ISO.jpg‎
Old 03-14-2010, 10:16 PM
DIYaholic's Avatar
DIYaholic is on a distinguished road
Smile Howdy!
adam_m,
Welcome to the Zone.
The answers to ALL your posted questions are answered here on the "Zone" in the various threads. The threads ben_jackson provided links to, are good places to start.
My advice to you is to determine what you want your machine to be capable of: ie. material to be cut(foam, HDPE, MDF, exotic woods, aluminium, even steel), size/thickness of material to be cut (this will determine your working envelope), tolerances needed for various materials, cutting feeds, rapid speeds, to name a few performance criteria. Along with performance criteria, you need to consider your budget, design skills, available tools, your building skills, electronics skills and your time constraints. The budget is usually one of the most critical aspect of any build. Who couldn't build the perfect machine(s) with time and an unlimited budget.
Once you determine your desired performance criteria, you then set out to design a machine to meet or exceed those criteria.
While doing your research, keep your performance criteria, build & design skills and budget, in mind. You have come to the right place to research/learn all there is to know about DIY CNC routers. The people here on the zone are ready, willing and able to share their knowledge and expertise.
Again, Welcome to the "Zone". Have fun reading/researching.
Randy,
I may not be good....
But I am S L O W!!
Old 03-15-2010, 01:13 AM
lunchtrayrider is on a distinguished road
take a look at the builds listed at cncrouterparts.com too. a couple of different styles that you can look at.
Old 03-15-2010, 05:52 AM
Thanks for the reply's. I see now that CNCRouerparts is where some of the supplies came from for jsheerin's CNC build or if he has a thread avaiable?
So does anyone know what he used for linear motion bearings on that setup?
I realize that critiquing designs isn't a polite thing to do but if you were to do it how does jsheerin design measure up, is it worth repeating?
DIYaholic, I've been doing a lot of thinking about material/feed/size. Since this is my first CNC I really don't want to bite off more than I can chew. I think MDF/Hardwoods and maybe Aliminum might be in the mix.
For table size I'm thinking 36 x 48 or somewhere in that range...
Thanks,
Old 03-16-2010, 06:18 AM
Any reply's to my earlier question(s)?
For electronics it looks like I can't go wrong using:
Gecko G540
KL23H2100-35-4B 381 oz motors
KL-350-48 48V/7.3A power supply.
There are also some auctions going on EBay with motors any thoughts as to which is better/worse 380, 381, 640?
http://cgi.ebay.com/4-Axis-CNC-Gecko...item3efcc47070
http://cgi.ebay.com/Gecko-G540-w-Fou...item1c10e2da8f
Any thoughts?
Adam,
Old 03-16-2010, 11:58 AM
I am using cncrouterparts.com motors, power supply, cables, and got a g540 from them. the coolest part about them is the motors come with connectors prewired with a current set resistor in them already for you. also the red cables make hook up a breeze. think long and hard about saving a few bucks and all the pain of making your own cables.
Old 03-16-2010, 01:17 PM
Any input into the above selections that I've made?
I'm also thinking about using 20mm supported linear rod for the x, y and z axis.. thoughts?
Thanks,
Old 03-16-2010, 05:12 PM
im guessing that the 380 oz/in motors from cncrouterparts along with the geckodrive g540 are going to generate the highest rpm. the cncrouterparts motors and the kelings are going to be the same. the other ones i have no idea. mine from cncrouterparts just fly with their rack and pinion system.
here is my setup that is what cncrouterparts ebay auction is for:
Old 03-16-2010, 07:03 PM
lunchtrayrider - I like the speed...
Do you have a link to your table assembly or some more details on what you used for your build, etc.?
It looks like its an 8020 build, what type of bearings did you use for the gantry and how is that assembly completed?
Thanks for any light you can shed..
Adam,
  #11   Ban this user!
Old 03-16-2010, 07:44 PM
Are you reading the replies? lunchtrayrider's build thread is one of the links I posted.
  #12   Ban this user!
Old 03-16-2010, 09:08 PM
Missed that, sorry.
Adam,
newbie need guidance 15mgtar Benchtop Machines 6 07-30-2009 12:52 PM
Newbie looking for guidance yellow CNC Plasma and Waterjet Machines 1 09-14-2006 08:40 AM
In need of guidance xcphil General Metal Working Machines 0 05-29-2006 01:41 PM
Need some CNC guidance seafire CNC Plasma and Waterjet Machines 2 11-15-2005 10:07 PM
Newbie seeking help. (mini mill guidance) Deviant General Electronics Discussion 2 10-25-2004 01:58 PM
