Old 03-12-2010, 09:05 PM
LessPaul is on a distinguished road
Gantry vs Bridge
Help a newbie understand.
From what I've read the Gantry type machine makes up the majority of hobby CNC machines, and the fixed Bridge design is used most often for metal milling.
What I was wondering is if there were any "combo" designs -- where the Gantry can be locked rigidly in place, and a small moving table mounted to the work surface. This would (seemingly) give a rigid bridge for metal milling smaller parts, and also work as a normal router. (Of course there would also need to be suitable spindles for both).
Just curious if it has been done, or if the complexity would be too high (i.e. one might be better off building two machines)
Old 03-12-2010, 10:31 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
LessPaul,
Most bridge mill's you see have massive casting's that are far more rigid than a gantry type CNC.
If you had a bridge mill you would not need a second machine as long as the work envelope fit the material needed to be machined.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-13-2010, 08:14 PM
YZF YZF is offline
YZF is on a distinguished road
How about this?
Old 03-13-2010, 09:28 PM
I don't know.... but for sure that is my new standard for CNC music.
Old 03-13-2010, 11:57 PM
YZF YZF is offline
With regard to locking a gantry design, the challenge would be to find a method of locking that makes a large enough difference in stiffness. A fixed bridge machine would generally have a heftier bridge all around, it's not just the linear axis. I think it might make more sense to just build a stronger gantry machine with the required stiffness.
Gantry: planning to design moving open gantry rdcd Mechanical Calculations/Engineering Design 0 11-14-2009 03:52 PM
Diffrences between bulltear cnc gantry kits and torchmate2 gantry kits tuf045 CNC Plasma and Waterjet Machines 2 09-14-2009 11:09 PM
Half bridge or Full bridge bunalmis General Electronics Discussion 3 04-13-2008 02:11 PM
Q: Y Axis - Gantry vs. "bridge" designs Zoid DIY-CNC Router Table Machines 9 07-06-2004 04:35 PM
Gantry or Bridge? jeffs555 DIY-CNC Router Table Machines 8 06-30-2004 11:42 PM
