Old 03-09-2010, 05:42 PM
elteks is on a distinguished road
anti backlash solution
I need a critique of this decision.
What do you think?
this might work?
P.S: Sorry for my English.
Old 03-09-2010, 11:46 PM
CarveOne is on a distinguished road
I don't see anything that holds the nut into the block when there is axial thrust in both directions. You would need more than the O rings to hold them together. A larger flange with two or three screws through it into the block is needed. The "fingers" of the nut look ok. These need to be allowed to flex but also have constant tension on them.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 03-10-2010, 12:48 AM
Pandinus is on a distinguished road
Not a bad idea at all.. the tension of the O-ring AND the compression of its rubber as well (assuming you get the fit that tight) I'm just thinking that any lube on the screw will climb the kerf and if not rubber friendly, harden the O-ring over time, but no light exposure is good... it should be fine for many years...
Old 03-10-2010, 02:37 AM
This is an example. In fact, the flange nut is held with two screws.
O-rings are not used to hold the nuts.
O-rings should only implement backlash compensation.
My question is the possibility of backlash compensation. This may work?
Old 03-10-2010, 10:02 AM
Gold Member
RomanLini is on a distinguished road
That system was used on some of the early Hewlett Packard large frame dot matrix printers. Actually they used circular springs but the same principle.
It works well for removing backlash but is only suitable for REALLY light loads like moving a printhead because it is flexible and elastic in both radial directions, and it's most flexible at the compression point where the actual drive takes place, and that is the worst point to have the flexibility.
Old 03-11-2010, 07:53 AM
Yes, it will work. How well it will work is determined by how much the axial thrust loads along the length of the Acme screws are. Some testing of a sample part should be done to see how well it works for your application.
CarveOne
CarveOne
Anti Whip solution for long screws? georgeburns DIY-CNC Router Table Machines 14 06-13-2008 10:46 PM
anti backlash nut? sixpence DIY-CNC Router Table Machines 13 07-18-2007 01:51 PM
Anti Backlash sala84 JGRO Router Table Design 3 11-05-2006 08:04 AM
Are those anti-backlash CnC_BoY Linear and Rotary Motion 6 03-20-2006 09:58 PM
Anti-backlash nut mikeschn DIY-CNC Router Table Machines 24 01-26-2004 10:55 PM
