Old 03-04-2010, 10:58 PM
mendez is on a distinguished road
Please Help with CNC losing steps
I have a HobbyCNC boad and I'm using Mach 3.
My CNC is loosing steps! I dont know why. It is working perfectly fine and then it gets like "Stuck" and Mach3 shows that an axis is running but is not, after 1 or 2 seconds starts running back again but it loos alot of steps.
What my be causing the problem? I check the CNC is fine
I check the Gcode and is fine
I even damage 3 pieces testing it and the fixing steps are different on each part. The missing steps are sometimes in X-Y-Z but most times on Y
Please help
Old 03-05-2010, 10:50 AM
ger21's Avatar
You're trying to go faster than your motors are capable of. Slow everything down. If it tends to stall in the same places, check for binding of your screws.
Old 03-06-2010, 02:04 AM
lunchtrayrider is on a distinguished road
computer?
are you losing a laptop to run the cnc machine?
Losing steps tjs88yj Viper Servo drives 11 02-24-2010 05:31 PM
Losing steps in Z - need help zeeway DIY-CNC Router Table Machines 9 02-13-2010 07:51 AM
Problem- Losing steps?? How do I know?? JeLC DIY-CNC Router Table Machines 28 09-09-2009 06:26 AM
Help with CNC losing steps Scramjet DIY-CNC Router Table Machines 6 01-29-2008 06:24 PM
Losing steps - WHAT IS UP?!? Sporqster DIY-CNC Router Table Machines 10 04-27-2006 09:50 AM
