Old 03-04-2010, 10:54 PM
crash5050 is on a distinguished road
Those Big Red Stopper Buttons?
I got one in the mail today and it was about the size of a quarter, I was under the impression that the were a lot bigger, After lookinh around the boards, I have seen big ones and little ones. Which way should I go? big? Little?
Old 03-04-2010, 11:13 PM
DIYaholic's Avatar
DIYaholic is on a distinguished road
Exclamation Does size really matter?
If you ask a women, the answer is YES, YES, YES, oh god YES! lol.
That being said, as long as the spec's of the switch match your setup and needs, then size does not matter (although, available space & mounting are key factors).
The other key issue is to locate the "Big Red Oh $hit" button were it is easily accessible.
Just my $0.02.
Randy,
I may not be good....
But I am S L O W!!
Old 03-04-2010, 11:23 PM
stangtjk is on a distinguished road
The big buttons are usually rated at higher amps and are used to completely shut off power. The little one are usually rated for lower amps and are used to signal an e-stop.
Old 03-05-2010, 05:20 AM
CarveOne is on a distinguished road
Just my $0.02.
Randy,
The large paddle type machine tool Estop switches are preferred by those of us with less than accurate pitching arms during true panic situations...........
I have one but haven't installed it yet. Home and limit switches either.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 03-05-2010, 07:04 AM
neilw20's Avatar
neilw20 is on a distinguished road
Mine's little.
I have a little one, and I NEVER have to use it anymore.
Only once when I pranged a cutter, and there was no danger once the cutter was gone (everywhere)
It never did any damage to the air that was being cut.
I have never used an emergency stop in anger, but it does work.
It should release a safety relay to make the whole machine safe, whatever that is.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 03-05-2010, 08:25 AM
Al_The_Man's Avatar
In N.A. one of the official stipulations for the E-Stop buttons is:
"Emergency actuator buttons or stop devices shall be coloured RED, The background immediately around the device actuator shall be coloured YELLOW, The actuator of a Push-Button shall be of the palm or mushroom-head type,
The E-Stop actuator shall be either a momentary or self-latching type"
In any case, it is usually the hardest to find button on the panel.
Old 03-05-2010, 09:42 AM
hemsworthlad is on a distinguished road
Ye i have the same problem but i'm not talking about my Estop. . Lol
You want one about the size of pumpkin and even then you'll miss it before the damage done.!!
Seriously thou like the lady's say size matters and if it's tiny it will be that much harder to scramble to hit, mine is about 2" dia and wired throu relays so to trigger a hardware Estop so when Big red button is released it doesn't start up again straight away and requires a reset button, relieing on software alone for an Estop is not safe. IMO.!!
Old 03-05-2010, 12:07 PM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Small up top and big down below.
I use the e-stop every single day, I have one at shoulder height, one at knee height and one near the floor so that when my brain screams "incomming!" I can still kill the bugger as I'm cowering amongst the chips.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 03-05-2010, 12:59 PM
Wot you dont have one at head height so you can slap the nut on
Old 03-08-2010, 04:01 AM
ImanCarrot's Avatar
lol I'm Scottish, but even I wouldn't nut my miller... it's a menace.
  #11   Ban this user!
Old 03-08-2010, 09:55 AM
revwarguy's Avatar
revwarguy is on a distinguished road
I have a big one - attached is a picture - its a bit over 3 inches wide, and is lit up when the machine is running. (Also reminds me that I left the machine on.) It is just a momentary push button, which is ok because it goes into the G540 which provides a positive latching function - you can't get the machine back on without doing a reset. It was $4 and was designed to be pounded (made for arcade video games.)
Note added later: I tried to attach the pic as usual, but CNCZone won't do it.
It can be seen at www.liming.org/cnc/page3.html about 2/3 down the page.
  #12   Ban this user!
Old 03-08-2010, 09:59 AM
underthetire is on a distinguished road
Actually, the new code says It can NOT be momentary, pull to release or twist to release only. And has to have a separate device to re-energize the machine.
Need Help!- Some help with EMC2, adding buttons.... Vegabond LinuxCNC (formerly EMC2) 4 08-27-2009 11:37 AM
extra buttons? Scooby Suggestions for the CNCzone.com site. 7 11-03-2008 05:35 AM
buttons going out? need help DerHammer Fanuc 13 03-09-2008 10:25 PM
Programing AUX buttons George C AjaxCNC Control Products 3 02-10-2007 01:33 PM
Some of my buttons are missing??? boxwood Forum Questions or Problems 2 05-17-2004 07:00 AM
