Old 04-22-2005, 11:08 AM
krebsatm02 is on a distinguished road
Worth anything?
I scrapped these components from a film line machine. They were used to control the height of a platform that a laser was mounted on. Just wondering if I could use any of this to start out with. Thanks - Doug
Old 04-22-2005, 11:10 AM
Old 04-25-2005, 04:42 PM
anyone?
Old 04-25-2005, 05:04 PM
TimKoene is on a distinguished road
No, they are not worth anything and you should send it all to me, I will dispose of them for you.
Seems like a good find!
Old 04-25-2005, 10:07 PM
Moderator
Halfnutz is on a distinguished road
It looks like you got three nice lead screws or ballscrews, its hard to tell, an encoder, and a power supply that might help. The motors dont look worthwhile messing with, good new mid range steppers are only 20-30.00 each now a days. Leadscrews or cheap ballscrews are at least 75.00 apiece.
Halfnutz
Old 04-25-2005, 10:12 PM
by the way, the motor is in 2 pieces because i took it apart to try to learn more about it. It was in fine shape when I got it and I bolted it back together. I was wondering about it though, the gear reduction part of it has the output shaft off centered and most of the motors around here seem to have a straight through configuration. Is it an odd motor for it to be offset?
Old 04-25-2005, 10:49 PM
ViperTX is on a distinguished road
It's a gearhead motor...therefore the offset. The steppers and servos used on most hobby systems are not gearhead....we tend to add timing pulleys and belt if we need the additional torque.
Tooling in Fort Worth, TX rcazwillis General Metalwork Discussion 5 04-26-2005 09:50 PM
Boss8 parts - what are they worth? fastturbovet Bridgeport and Hardinge Mills 1 04-08-2005 06:47 AM
Once converted, how much are they worth? Noah General Metal Working Machines 7 12-24-2004 05:23 PM
Galil DMC-2150 worth getting? h3ndrix General Metal Working Machines 1 03-10-2004 09:42 AM
Worth it CNCadmin Benchtop Machines 3 04-01-2003 11:21 PM
