Hi everyone. been a while since last post on an engraver I built. I have a Thermwood C50 router I'm in the middle of retrofitting with a new control system. I already have a pc to run it and plan on using the original DC servos and drives (old but solid BALDOR gear) these drives did not resolve the encoder signals but left it to the controller to handle. I need a control board that will handle an X with 2 motors, encoders and drives, a Y with 1 motor encoder and drive and 2 Zs (this machine has 2 spindles with independent vertical control. I'm sure there's some way to slave the 2 X drives together but still have 2 Zs. The controller needs to have encoder inputs and support analog output to the drives (not step and direction like stepper drives would use). I've looked at the camsoft stuff but cant find any pricing (need to call). I think I used camsoft on my engraver. Planning on using Mach for the software as I am very familiar with it and like the way it works. I need to pull this off on the cheap but want something that has a good rep. What do you all think? (motion control board) |
| The Mach plugin doesn't (and can't) really use the full feature set of the Galil boards, or the full speed. Either way, the Dynomotion cards come with software and they're definitely fast enough at a much better price than the Galil cards. If I needed absolute top speed then I'd go with the Galil stuff, but I'd program my own software (and would have to) |
| Wow, Dynomotion looks pretty good for a better price. Many using these? What do you think about the bundled software? better with Mach? I believe the Kmotion supports the required analog output reqd by my drives but the newer less expensive Kflop does not? |
That's what the KAnalog is for. |
| Need Help!- Need help wiring a BioDot xyz control board | pumpkinking | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-29-2009 01:05 PM |
| MC116 board T32 control | Captdave | Want To Buy...Need help! | 0 | 06-29-2008 05:01 PM |
| Need Help!- Seig x2 Speed Control and c6 Control Board | skmetal7 | Benchtop Machines | 2 | 04-21-2008 03:17 PM |
| Need Help!- Control Circuit Board Pin ID | j-miller.6 | Fadal | 0 | 01-27-2008 03:00 PM |
| recomended gecko drive for 7X12 | northernmach | Mini Lathe | 3 | 02-13-2007 09:30 PM |
