Ok update I removed some of the grease from the trapezoidal spindles it is thick stuff even more so in this weather.
I then added some 3 in 1 oil just to loosen things up a little and now I have had NO stalls,stops,jams etc so maybe the grease was way to thick in this weather I will look at the details on where I got it to see if its recommended to be used in 2c conditions.
