Originally Posted by
Action-KAT
The motors are 175oZ
I plan on cutting wood mainly 3D shapes.
I would like as much torque as possible I think this would be better but I also think that matching the Voltage and amp as close to the controller and motor will make the most of the Torque of the motor.
Most of the motors I have looked at with higher torque the amps are above 3A of the G540, the voltage is ok and under the 50V.
So go with 175oZ motors & G540 or get bigger motors 600/1200 oZ & use 7Amp gecko's.
I should look at what I can get away with motor size next now I know the relationship between motor, amps and Volts..
Thanks for your help I can see clearly now
Cheers
KAT
