Lets build a cnc robotic arm!!
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Lets build a cnc robotic arm!!
    Jul 2007
    Argentina
    Default Lets build a cnc robotic arm!!
    does anyone has tray to make a robotic arm?
    Does anyone have plans?
    I have the idea on my mind and the past weeks i collected a few parts usefull for building one. i also downloaded and installed Mastercam and Robotmaster plugin for it, but not figured out already how to make one to plug-in to the computer.
    Anyone?
    Servos without exception? Or i´m able to use steppers?
    Parallel port conected? step, dir, and enable are enough?
    The intention i have is to build a robotic arm (I counted 5 motors needed) to make the exact same shop as a small cnc router for wood). Lets say a working area of 40x40 mm.; So i´m guessing that nema 23 stepperas are enought for the project (gear reduction needed, of course).
    by the way, it will be amazing if some genius build a plugin for controlling robotic arms with mach3.
    Gold Member
    Dec 2005
    a 3 or 4 axis mill, or even more so a hexipod is really just a special purpose robot arm, better suited for accuracy and precision when you want to mill or engrave something. Your robot arm will get really beefy in a hurry if you try to make it not flex when taking even light cuts. I guess there is a reason the Fanuc welding robot arms are 3000 to 4000 pounds...
    Apr 2004
    Omaha, NE
    Quote Originally Posted by patriciooholegu View Post
    [snip]
    I don't know much about mach3, but there are a number of kinematics modules for emc2 that will control robots configured as you describe.
    Jul 2007
    Argentina
    yes you have a point there.
    Anyway, wath about this: I always wanted to build a machine to paint marquetry on my fornitures. On the next summer (One ear from now. it´s summer in Argentina) i have plans to make a bussines were the furnitures will be made alive by cnc machines, and it cross my head the idea that a robotic arm, instead of a simple cnc table, will be very more atractive.
    So, a cnc controlled robotic arm, to HOLD A PEN (And in the future, more then that...).
    So far a have chequed the user interface of robotmaster and have no clue, jajaja!!! (Installed on Mastercam), and have seen some matterials usefull (steppers, aluminium stock... also i have 5 servomotors savaged from copier machines with drivers...)
    Any idea will be lovely.
    By the way, sorry about my inglish.
    Jan 2007
    Well im all for helping on this project. Ive designed a rather large robotic arm before. Haven't built it yet, but i got SW drawings and models of it. My arm houses all the motors in the base. It is better for strength, but im sure adds backlash to the end effecter. Im sure my plans might be able to be adapted to work, if not, I can start something new. I like challenges. lol. Let me know what you think.
    -Adam
    Attached Thumbnails Attached Thumbnails Lets build a cnc robotic arm!!-arm-jpg
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    Registered FandZ's Avatar
    Oct 2008
    You have my attention.
    Quote Originally Posted by Adamj12b View Post
    -Adam
  7. #7
    Sep 2007
    South Africa
    I need to build a robot arm to feed seedlings from seedling trays into a planting arm.
    Problem1: Electrical power 12v DC only. The ram needs to be robustly driven in three axis, x,y,z. The arm will be fitted on a tractor, so the platform will move and shake.
    If electric drive, where to find power steppers or servos?
    Hydraulics appear to be out, as small hydraulic cylinders are unobtainable here.
    Pneumatics have the problem of starting slow due to the inertia, then pick up speed uncontrollable. Not on. The end effector has to stop resonable precisely at every seedling.
    Preferrably the power source must be stationary to minimise the inertia. How to control the arm? Cables? Chains?
    Polar control or cartesian?
    Any help will be much appreciated.
    Thanks Smitjs
  8. #8
    Jan 2007
    Hi Smitjs,
    Sounds like an interesting project. Some important questions though. What is your budget? Also, what is the tractor that this will be behind? Will it be mounted directly to the tractor or just on some form on trailer? What is the reach needed?
    When you mentioned tractor, my first thought would be use a backhoe, modified with computer controlled valves and position sensors on the pivots. No need making some kind of power when a tractor is providing it. The only drawback to this idea that I can see as of right now is the moving speed of the arm.
    -Adam
  9. #9
    Sep 2007
    South Africa
    Hi Adam,
    Thanks for the reply.
    Not on a trailer, but built onto a Bell SJ315 tractor.
    The size of the seedling tray is 750mm x 350mm. Maximum reach therefore in the order of 1m. Valves and computer control is not the problem, it is how to turn the tractor power, 12v, hydraulic, or pneumatic pressure into controlled arm movement. Hydraulics seems to be unavailable in small scale, and pneumatics appear to be good only for fixed end points. In this instance the end effector on the arm must stop at any of 128 specific positions.
    Strong steppers or servo motors will do well, I think, but unavailable for 12v.
    The drawback of pneumatics is the compressibility of the air. There is no fixed position except at the endpoints. Ideally, small low pressure cylinders with some or other fluid will be nice.
    Any suggestions appreciated.
    smitjs
  10. #10
    Jul 2007
    Argentina
    Default Robotmaster help
    so people i steel trying to undestand how to manage robotmaster before starting to develop my robot. I have all i need refering to hardware for it (Electronics, aluminium, steppers, etcetera) but Robotmaster drives my nuts.
    does anyone now if it is posible to asign pins for step, dir and enable trough parallel port with this software?
    I didnt find any help so far on any web page.
    Please help!
  11. #11
    Nov 2008
    indonesia
    Smile
    Hello everyone, FYI maybe this link could be useful http://cncfanuc.blogspot.com
  12. #12
    Mar 2009
    Cool
    Can't help you with plans, but I make all the parts for this robotic arm on a Haas VF-Milling Center and lathe.
    Pretty cool unit they sell. The robots are not sold by us.
    http://www.themachinelab.com/news/MM...OD%20Specs.pdf
  13. #13
    Dec 2008
    How about this type of robot arm. Cheaper, more rigid and fasssst.
    these are two I made with nema23 motors.
    [nomedia="http://www.youtube.com/watch?v=lkbFCVcRP88"]YouTube - Fast 140ppm mid sized delta robot[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=Gv5B63HeF1E"]YouTube - Mini Delta Robot with background noise to verify actual speed[/nomedia]
    one has 8in workspace, the other has 15in workspace
    Jamison
    www.deltarobots.com
    Home Page
  14. #14
    Mar 2009
    Wink
    That is so cool, just don't know what I'd do with a Chinese checkers playing robot arm!
  15. #15
    Dec 2008
    Yeah, more of a pick and place application than anything else. But its cheap and fast for a home built...
    I make hexapods too. They aren't as fast but stiff and cheap.
    Fun, perhaps useful, and good for the brain.
  16. #16
    Registered jcoats's Avatar
    Nov 2005
    several years ago, in a magazine like Radio Electronics (my memory is wrong I am sure), there were plans over 3 of 4 months on building a robotic arm. It could be made
    with a drill press and some mild steel rod. For the major movements, it used DC motors to drive gears, that then turned all-thread rods. It would still be fun to make.
    Anyone know where to find the magazine (it might not be RE!)
  17. #17
    Apr 2006
    na
    Default robotic arm
    Anyone working on a diy robtic arm? Or have links for a design.
    I have a few questions on what cam programs are avail ... that support the cordinates required to drive a arm? I dont think mach 3 supoorts them.
    ie kinematics module ie translate cartesian coordinates/paths into
    rotational joint position
  18. #18
    Nov 2003
    manitoba, canada
    I'm going to build a shop robot arm one day suspended by overhead gantry. But it will be more of a software experiment than anything else, visual recognition, and learning program. I don't know why people bother with trying to do what should be done with the right equipment with equipment that wasn't designed for the job... on a budget?
    oh well
    parts are available on ebay for making a simple robot arm. There is no real point in trying to manufacture it yourself...
  19. #19
    Nov 2005
    Some folks enjoy the process of building, some enjoy the software problem, getting it all together to have it work well is the goal for us all.
    Still the interface of the two worlds is the hard part. The sensors and corresponding control systems (hardware and software) are non-trivial
    at least until the path has been trod several times. (CNC machines and Laser cutters are getting to be common place, but only in the last few
    years have they become fairly common and available to the hobbiest to use and understand without costing a fortune! - at least that is my cut at it)
    As you make the journey, all we can ask is to document it and bring us along for the fun, and to provide assistance from the peanut gallery!
    What kind of an arm are you planning?
    Last edited by jcoats; 12-28-2011 at 07:51 PM. Reason: Expounding on terse statements
  20. #20
    Nov 2005
    Quote Originally Posted by eloid View Post
    http://www.pathfindersdesignandtechn...obotic_arm.pdf
    has a simple 3DOF pneumatic arm.
    I remember seeing plans a couple of places some time ago. One was basically a duplication of an old arm, using tapered sheet metal boxes for the portions of the arm, plus the end effector (hand). Reach was pretty minimal (12" on direction or so if I remember right).
    Another used steel rods for the structure. With geared bolts with analog motors for actuators.
    There was a third that was an 3 legged gimble system. like "http://www.youtube.com/watch?v=LJYhz5aTMnA"]this HexaPod on YouTube.
