Lets build a cnc robotic arm!! - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Lets build a cnc robotic arm!!
  1. #21
    Registered jcoats's Avatar
    Nov 2005
    Post What kind of an arm?
    Quote Originally Posted by eloid View Post
    Anyone working on a diy robtic arm? Or have links for a design.
    I have a few questions on what cam programs are avail ... that support the cordinates required to drive a arm? I dont think mach 3 supoorts them.
    ie kinematics module ie translate cartesian coordinates/paths into
    rotational joint position
    http://www.pathfindersdesignandtechn...obotic_arm.pdf
    has a simple 3DOF pneumatic arm.
    I remember seeing plans a couple of places some time ago. One was basically a duplication of an old arm, using tapered sheet metal boxes for the portions of the arm, plus the end effector (hand). Reach was pretty minimal (12" on direction or so if I remember right).
    Another used steel rods for the structure. With geared bolts with analog motors for actuators.
    There was a third that was an 3 legged gimble system. like "http://www.youtube.com/watch?v=LJYhz5aTMnA"]this HexaPod on YouTube.
    This web site has several different types of EMC2 controlled robot arms: HERE
  2. #22
    Apr 2006
    na
    Quote Originally Posted by jcoats View Post
    There was a third that was an 3 legged gimble system. like HexaPod on YouTube.
    no im looking for plans for a Articulated arm 5 axis, that has 4x4 reach
  3. #23
    Apr 2006
    na
    Default Articulated arm
    the more I look at 5 axis gantry with c b axis cncs the more beleive
    fabricting a Articulated arm would less work. To bad mach does support
    kinematics like emc.
    http://www.youtube.com/watch?v=o4Fns7B2SII&feature=player_embedded]EMC2 ROBOT ANTROPOMORFO 6 ASSI------ - YouTube
  4. #24
    Jul 2009
    NL
    Quote Originally Posted by smitjs View Post
    Hi Adam,
    it is how to turn the tractor power, 12v, hydraulic, or pneumatic pressure into controlled arm movement.
    smitjs
    Add a bigger alternator to the tractor and use a good quality inverter to turn it in to 230V (or 110 if applicable) or even use a generator. Both seem so much easier and cheaper than finding stuff to make everything work on 12V
    Sven http://www.cnczone.com/forums/diy-cnc-router-table-machines/320812-aluminium-1250x1250x250-router.html
  5. #25
    Dec 2010
    us
    Default Starship groove robots
    Check out this video STARSHIP GROOVE on my website lets build one of theseBuild Your Homemade CNCGo to the starship groove link there and watch the video and tell me is it possible to build this one Tom
  6. #26
    Registered frankg521's Avatar
    Aug 2006
    Im in.... i would like to build a arm also please keep this thread going
  7. #27
    Apr 2006
    na
    Default arm
    To keep this thread going, we need determine where to source parts or fabricate them post drawings share ideas, post photos of commerial arm... and determin what arm are most practical to build and costs and material to be used. Check my thread on 5 axis schematic, and videos on other arms.
    http://www.cnczone.com/forums/diy-cn...schematic.html
  8. #28
    Dec 2010
    us
    Default 6 axis mach3 CRAZY
    I like the 6 axis mach3 setup if your thinking of building the arm in the Starship Groove posted above you willneed at least 6 axis to do this I think we should use 6 nema 17s w/chains and sprockets for reduction lets build this one I have never seen one like this the starship groove is all just 3ds max kinetics cyber robots all artificial.
    Thanks Tom
  9. #29
    Apr 2006
    na
    Default robotic arm
    Quote Originally Posted by gualalasmooth View Post
    Thanks Tom
    hex apod is cool design but for my needs it doesnt have the dual wrist action i require for full 3d designs that have completated undercuts , also ( large working area... foot print 5'x10')
  10. #30
    Apr 2006
    na
    post a direct link, for it...
  11. #31
    Apr 2006
    na
    If anyone is interested in designing / sharing ideas for a robotic arm check out my thread on 5 axis robotic arms
    http://www.cnczone.com/forums/diy-cn...hematic-2.html
