this little paper is traditional chinese say this, you can copy & paste to google
"請將電機直接接入變壓器UVW上,中間嚴禁安裝任何的開關電容器件,否則會引起變頻器損壞"
my english not goog so i type to google translate, google translate is "You direct access to the electrical transformer uvw, the middle is prohibited to install any parts of the switched capacitor, otherwise the damage will be caused by inverter"
my bundle same to your VFD but my spindle is 1.5kw air-cooled, i hope i can be help you
This might help - pictures showing a Delta VFD at work!
http://www.mechmate.com/forums/showt...&postcount=156
Pin 1 of spindle to VFD “U”
Pin 2 of spindle to VFD “V”
Pin 3 of spindle to VFD “W”
Motor pin 4 unused
Ground the case of the motor to ground
Dont put anything between the VFD and spindle. (just like your stepper motors and drives).
read the english manual as posted earlier in this post. It will explain everything clearly.
These guys seem OK as the E-bay feedback shows.They can quote on parts not listed in the store.
EG 4.5kw/380V/3ph watercooled spindle:$590US+$155US shipping
7kw/380/3ph:$720+201 shipping.
This does not include VFD but there is tons of VFDs on Ebay
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Translation:
"Directly connncet the inverter to UVW in the VFD. Do not connect any Capacitor between Inverter and VFD. If so, it will damge your inverter"
For this inverter one ebay, The Bearing is not Original NSK bearing (Less life time) . The NSK bearing cost more, but run longer.
http://www.kelinginc.net/CNCSpindleandController.html
I now have one of these Chinese spindles. This is what the guy sent me for wiring. I got it up and running pretty quickly but some of the VFD settings didn't hold their values. The guy said it was a spindle issue and I was to return for a replacement. Still waiting on replacement. I did have it running and ran a small job just to use it. All I can say is "why didn't I do this sooner"! This thing is so quite. I will not miss my Porter Cable at all.
Thought I would add this too, this was in his email;
1. I drafted the wire picture to you in this email attachment
2. I added the manual in this email for you
3. I just tell you how to set up vfd as following
Firstly, adjust the PD013 to 8
Secondly, adjust the PD005 to 400
Thirdly, adjust the PD004 to 400
Finally, adjust the PD003 to 400
Note: you should set PD013, PD005 ,PD004,PD003 in order.
Make sure to NOT set PD013 to 8 AFTER you set your other parameters (unless you mean it). PD013 set to 8 resets the system back to the factory defaults.
Has anyone tried to run the HuanYang VFD over MODBUS/RS-485 with Mach 3?
I have the HY02D223B and may give it a try.
So far everything is going fine. Thanks guys.
Now, if someone knows how to change the chuck, and what compatible chuck would fit on our Chinese spindle.
The spindles have an ER collet. The 1.5KW spindles have usually an ER11 collet and the 2.2KW spindles usually have an ER16 collet. Double check the size, don't take my word for it.
Actually my 2.2kw came with ER 20 but I think it is pot luck as to what you get unless you specifically ask.
David
Not to hi-jack your thread but I'm considering a chinese water-cooled spindle from this guy. I have read reviews from a couple of folks who are pleased with this seller and the feedback looks pretty good. You gotta love the name too!
Love-Happyshopping
Anyone ever dealt with them/him/she?
Thanks,
Matt
Yes, I have the 2.2kw water cooler and the 1.5kw air cooled spindle from them and was very happy with the service.
I made my own mount for the 2.2kw as shown in the pictures below which if you are interested in one let me know.
David
I have a 1.5KW air cooled spindle from that seller and I'm happy, they are a very friendly seller.
Yes I'm trying. (thats what my wife tells me!) and a mate of mine has posted a little VB test app that works great outside of mach to control and get feedback on speed and current draw from the VFD. Its posted on here:
http://www.cnczone.com/forums/showth...light=huanyang
Now to figure out the hard part of getting Mach to say the same thing. Unfortunately this VFD seems to have a non standard (ie not mach modbus) command string structure.
Cheers
Mark
