That's fine for the hardware... What about the software?
I keep mine clean by adding this line to the Autoexec.bat file..
FORMAT C: /Y
It takes it a while to boot up, but it runs like a new computer every time!
'Rekd teh Inebriated
I have always been in a quandry of how to keep the computer clean in the workshop without having to encase it in a box that usually gets too hot (previous bad experience....imagine burning plastic smell....). I ran across this product today. It basically is a static free sleeve that goes around your PC.
I found it at......ready.......and I assure you it is not a porn site...
http://www.dirtbag.biz
I have ordered one and will let you know how it works
Paul Riedlinger
Let the chips fall where they may...I'm not going to clean them up!
FORMAT C: /Y
What does c:/y do what is that switch?
Thank You,
Paul G
Check out-
[URL="http://www.signs101.com"]www.signs101.com[/URL]
That will format (erase) your drive and not ask "are you sure?" first.(bad)
Eric
I wish it wouldn't crash.
Ooh no wonder why I don't know that switch, not a very nice post now was it!
Thank You,
Paul G
Check out-
LOL so you have to load all the time huh?Originally posted by FukNRekd
FORMAT C: /Y
To funny.
I would not do that.
To keep your system in good shape, you can use whats called
System works 2003 from Norton.
Really does a good job on the pc systems...
Now FukNRekd are you going to come over and not play nice.
Don,t make me pick up my marbles and leave now.
Cadcam
Turning Product Specialist for a Software Company, contract Programming and Consultant , Cad-Cam Instructor of Mastercam .
You know me better than that, cadcam. It's all in fun. (The /Y command is not listed when you do a FORMAT /? 'cuz it's dangerous.)
And if I remember correctly, I won all your marbles the last time we played together...
'Rekd teh Marble King
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
In most computer enclosures, the fans blow outwards, creating somewhat of a vacuum inside the case, drawing cool air in through holes in the front. A dusty environment allows dust into the case through these holes because of the lower pressure inside the case. What I have done is run small flexible ducting from outside the dusty area with a fan on the case blowing inwards, creating higher pressure inside the case than out, thus preventing dust from entering while still providing airflow to cool the components.
Happy New Year,
Steve
