The bottom of the spindle measures 60mm / 2 3/8" I'm wondering if anyone has experience with these and will the 65mm collar tighten onto my 60mm spindle?
I have one, though it arrived after I took my machine apart. It seems well built, and easy to install and remove for tool changes. All measurements are accurate for my model. Its a cheap solution, and that should be taken into consideration in case it breaks. the brushes in mine are pretty bad quality and I expect them to mostly fall out soonish, and the welds are literally just tack welds.
Thanks for the reply, yes I understand they are cheap & may not last but I figure it will work until I gain CNC experience & can design & make a higher quality diy version. Anyone else have any insight?
Cut a practice one out using MDF... then order some 1/2" acrylic from ebay (about 12x12") and a 36" length of flexible brush from Mcmaster Car, get some round neo magnets and cut one out yourself. Spend about the same or less than the metal one from ebay and you'll have a much nicer dust shoe in the end. No reason you can't build it in a day or weekend and you'll have a great project to learn with.
