Proximity Sensor Wiring Issue? Help needed. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 43
Thread: Proximity Sensor Wiring Issue? Help needed.
  1. #13
    Mar 2017
    Default Re: Proximity Sensor Wiring Issue? Help needed.
    I looked and my sensors today and they have this label.
    Proximity Sensor Wiring Issue? Help needed.-img_20180213_120112-jpg
    So from what I understand they are NPN type but they are wired like this on my BOB.
    Proximity Sensor Wiring Issue? Help needed.-pnp-proximity-sensor-jpg
    Almost the same as in my case except that my blue cable goes to the load bob terminal instead of -12v and common terminal on my bob is connected with -12v.
    But from what I see on those pictures it seems to be correct in my case.
    Proximity Sensor Wiring Issue? Help needed.-pnp_en_1-png
    Proximity Sensor Wiring Issue? Help needed.-npn_en_1-png
    Attached Thumbnails Attached Thumbnails Proximity Sensor Wiring Issue? Help needed.-img_20180213_120112-jpg   Proximity Sensor Wiring Issue? Help needed.-pnp-proximity-sensor-jpg   Proximity Sensor Wiring Issue? Help needed.-pnp_en_1-png   Proximity Sensor Wiring Issue? Help needed.-npn_en_1-png
  2. #14
    Dec 2005
    based on the picture with the label attached. The+12V connect to the Brown . 0V or ground connects to the Blue and the input to the BOB connects to the Black wire of the sensor , this is an NPN sensor. Black is the sensor output ,Brown and Blue power the sensor, In your original wiring diagram you show 2 black wires coming out of the sensor, and the Black wire coming out of the sensor should connect to pin 12
  3. #15
    Gold Member john-100's Avatar
    Mar 2007
    uk
    the wire link I added to the BOB was to connect the missing +5V supply to pin 14 of the 74HC14 IC used to buffer the 5 BOB inputs
    Proximity Sensor Wiring Issue? Help needed.-chinese-bob-74hc14-5v-pins-jpg
    now I have looked at the photo of the proximity switch label
    I have changed the colour of the wiring to match the colour of the sensor wires
    Proximity Sensor Wiring Issue? Help needed.-proximity-sensor-wiring-v3-jpg
    with the mains earth/ground connected to the spindle to protect you from a possible shock due to a fault in the motor or the cable
    you could have a problem due to an earth loop as the BOB's ground terminals are connected to the the mains earth /ground via the PC's power supply
    the addition of an opto-isolator to the touch probe is one solution
    John
    PS
    example of ready made opto-isolator board
    Proximity Sensor Wiring Issue? Help needed.-example-ready-made-opto-isolator-board-jpg
  4. #16
    Dec 2005
    that looks correct now, many of the proximity sensors wire this way. Brown to +V Blue to -V or Gnd. Black is the switched output
  5. #17
    Dec 2005
  6. #18
    Dec 2005
    some of those ebay Chinese BOB's have opto inputs
    Attached Thumbnails Attached Thumbnails Proximity Sensor Wiring Issue? Help needed.-mach3-bob-opto-jpg
  7. #19
    Mar 2017
    Thanks for the help guys.
    At the moment I do not have issues with my probe. Since I added the capacitor everything works fine.
    About the connection of pin 14 to +5v, my knowledge in electronics is limited so I do not understand what means that inputs are buffered. What is the difference of buffered inputs vs non buffered?
  8. #20
    Dec 2005
    it means your input signal connects to a buffer before it goes to the parallel port .non buffered means you connect directly you the parallel port. the buffer in your case is a the 74hxx chip which acts as a unity amplifier
  9. #21
    Mar 2017
    Hmm and what purpose does the buffer serve? Does it have something to do with noise filtering or something like that?
  10. #22
    Dec 2005
    it can provide additional output and clean up the signal , it is a simple amplifier . it cannot isolate like an opto
  11. #23
    Mar 2007
    uk
    this is part of the circuit diagram of your BOB
    note - this shows only one of the five identical input circuits
    also note the missing +5V supply to pin 14
    Proximity Sensor Wiring Issue? Help needed.-chinese-breakout-board-input-circuit-jpg
    the 74HC14 used is a Hex inverting Schmitt trigger
    when the input is at +5v the output is at 0V and vise versa
    having the schmitt trigger input it also sharpens up slowly changing signals so they have sharp edges
    so they are seen as a logic 0(0v) or logic 1 (+5v) not some vague level between 2V & 3V
    the 74HC14 has 6 inverting Schmitt trigger circuits inside
    Proximity Sensor Wiring Issue? Help needed.-7414-jpg
    john
  12. #24
    Mar 2017
    Got it. Thanks for the explanation
