Congratulations. Very nice work, though the picture is so small it is very hard to see.
I've completed a new build, with cable enclosure, and all goodies.
- Two 12" travel linear slide for X axis
- One 5" trave linear lide for Z axis
- 3x NEMA 23 (420 ozin) from longs motors
- Optically switched, with transistor inversion on Z axis
- SSR relay for spindle router
- GRBL powered
- Raspberry PI for control side
More images on boxedcnc: A new CNC router
Cheers
Alessandro
- 0.4MIL High Precision CNC Router Equal to CNC Lathe Machine Precision
- How to identify Hiwin Precision class: (H) High Linear rails
- K2 CNC Router 8" Linear Actuator Slide - Add to KIT DIY
- K2 CNC Router 8" Linear Acutator Slide - Add to KIT DIY
- Just IN- Heavy Automotive Welding Crane Guided by PBC Linear Drawer Slide Precision
https://www.youtube.com/c/AdaptingCamera/videos
https://adapting-camera.blogspot.com
Thank you A_Camera, please find attached a bigger version of the image, plus a youtube link during setup.
Maybe interesting for the forum:
- SSR to start/stop spindle motor
- Transistor to invert only Z optical limit switch in series due to the fact that XY are normally open, and this is normally closed: GRBL does not accept mask (Actually).
Youtube video:
Only if more curious on other works:
- EMBROIDERY CNC (long series of build): https://boxedcnc.blogspot.it/2018/02...eted-work.html
- MF70 BOXED CNC (with brushless motor controller): boxedcnc: BOXED CNC: Brushless Spindle & Controller, MpIde sketch
Alessandro
Last edited by juppiter; 02-04-2018 at 01:12 PM. Reason: more link and Video highlight in the topic
