That router should be able to sail through the MDF with only 0.25 DOC with a 1/4 carbide bit. The gumming up might be because the router is running too slow. Sounds like the router is not working correctly. I can run a 1 inch bit 0.375 deep with my Porter Cable 7518. It's a little more power than yours, but not that much.
