the work space is 160mm x 100mm x 45mm. but id rather go by inches because thats what I grew up on so I rounded it to 6x4
Now you know how your code needs to look like, that is a standard format that should run on any modern control, I checked and there are a list of Grbl user codes, there are some important ones missing, but for just engraving and mill it should work fine
What you need to do is find a cam program that the postprocessor will output the G code program just like I supplied for you, some cam programs you can adjust how the code is output by adjusting the postprocessor
At the very end of the program, you can add this to it, this will move your X or Y axes to anywhere you want it at the end of cutting, I did not know what travels your machine has so only gave the Z axes 1" or 25mm retract at the end of cutting, you can make this Z retract any number you like to clear any obstacle's before a X Y move
The cutter size for this 2" square was 1/4" so you could cut this part if you wanted to, Z axes Tool Zero would be to the top of the part, the cut is 1/4" deep 4 passes
End of program
1X.1192Y.296
G3Y.3808I-.0424J.0424
G0Z1. ( this is where you retract your Z axes to where you want to clear your part )
M5
G53 X0Y0 ( This is where you can add any number in the X and Y Plus the G53) I would of had this in there but did not know if you control would except it, I know now that it does, so you can use the G53
M30
Mactec54
so i guess i need a CAD/CAM program and start playing around, is there a free one that does both or do I need a separate CAD CAM?
Fusion 360 is a professional CAD/CAM package. It's free to hobbyists. A bit of a learning curve, but there is a lot of online tutorials and support.
Jim Dawson
Sandy, Oregon, USA
only a 30 day free trial than it cost a good amount. lets skip free and use a different word, "easy to learn" does inkscape seriously not work? I watched a youtube video and copied it step by step and it worked on his.
Fusion 360 is totally free of charge to students, hobbyists, and small businesses with less than 100K annual income..
https://knowledge.autodesk.com/suppo...usion-360.html
Inkscape....You have already generated G code with it, you just need the correct post processor for a GRBL machine. There should be a way to choose the post processor.
Jim Dawson
Sandy, Oregon, USA
The included CAM comes from HSM, which is a professional CAM package.It's not even close to a main stream ( professional ) cad/cam package
Fusion 360 does both.parametric modeling, is out dated and has been replaced, by direct modeling,
Help
Fusion 360 is not perfect, and may not be suitable in all professional applications. But it can do at least 90% of what other high end CAD/CAM packages can do, for free, or a fraction of the price.
Tell us what's comparable, that hobbyists can afford?
UCCNC 2017 Screenset
