Need Help! Help with DQ860MA Driver
Results 1 to 2 of 2
Thread: Help with DQ860MA Driver
    Sep 2017
    Default Help with DQ860MA Driver
    HI All
    I'll really appreciate your help
    on acceleration and deceleration I have terrible noises ( something like the step motor goes step by step or under very heavy load )
    on high RPM ( of the step motors ) they work pretty smooth ( jogging at 1000mm/s )
    it's based on Arduino GRBL V1.1
    I attach my motor connection schematics + Driver setting + GRBL Settings
    ======================== GRBL Settings ========================
    $0 = 10 (Step pulse time, microseconds)
    $1 = 255 (Step idle delay, milliseconds)
    $2 = 0 (Step pulse invert, mask)
    $3 = 4 (Step direction invert, mask)
    $4 = 0 (Invert step enable pin, boolean)
    $5 = 0 (Invert limit pins, boolean)
    $6 = 0 (Invert probe pin, boolean)
    $10 = 0 (Status report options, mask)
    $11 = 0.010 (Junction deviation, millimeters)
    $12 = 0.002 (Arc tolerance, millimeters)
    $13 = 0 (Report in inches, boolean)
    $20 = 0 (Soft limits enable, boolean)
    $21 = 0 (Hard limits enable, boolean)
    $22 = 0 (Homing cycle enable, boolean)
    $23 = 0 (Homing direction invert, mask)
    $24 = 25.000 (Homing locate feed rate, mm/min)
    $25 = 500.000 (Homing search seek rate, mm/min)
    $26 = 250 (Homing switch debounce delay, milliseconds)
    $27 = 1.000 (Homing switch pull-off distance, millimeters)
    $30 = 1000 (Maximum spindle speed, RPM)
    $31 = 0 (Minimum spindle speed, RPM)
    $32 = 0 (Laser-mode enable, boolean)
    $100 = 640.000 (X-axis travel resolution, step/mm)
    $101 = 640.000 (Y-axis travel resolution, step/mm)
    $102 = 640.000 (Z-axis travel resolution, step/mm)
    $110 = 2000.000 (X-axis maximum rate, mm/min)
    $111 = 2000.000 (Y-axis maximum rate, mm/min)
    $112 = 2000.000 (Z-axis maximum rate, mm/min)
    $120 = 100.000 (X-axis acceleration, mm/sec^2)
    $121 = 100.000 (Y-axis acceleration, mm/sec^2)
    $122 = 100.000 (Z-axis acceleration, mm/sec^2)
    $130 = 200.000 (X-axis maximum travel, millimeters)
    $131 = 200.000 (Y-axis maximum travel, millimeters)
    $132 = 200.000 (Z-axis maximum travel, millimeters)
    Attached Images Attached Images
    Sep 2017
    Default Re: Help with DQ860MA Driver
    Any one ?
    Any ideas ?
