Need Help! My router went today on my old DIY table need advise - Page 5
Page 5 of 7 FirstFirst ... 234567 LastLast
Results 49 to 60 of 73
Thread: My router went today on my old DIY table need advise
  1. #49
    Jun 2017
    Default Re: My router went today on my old DIY table need advise
    I received an email back from Bosch USA they needed name company name address & phone number before they could answer any questions. I supplied the missing information so hopefully I'll hear from them tomorrow
  2. #50
    Mar 2004
    Wisconsin
    Quote Originally Posted by ger21 View Post
    Go with the air cooled, and forget about dealing with the water cooling.
    https://www.ebay.com/itm/FOUR-BEARIN...IAAOSw1vlUtyPk
    Ger, do you know whether the air path goes up or downward on that unit you linked ?
    Chris L
  3. #51
    Mar 2003
    They all blow down.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  4. #52
    Jun 2017
    I finally got to talk to Steve at Bosch/Rexroth he asked me a few questions I didn't know the answer. One of the questiobs was what is "Connection Protocol" I use Desk CNC and from the research I see where it says PWM Output for spindle speed control.
    My question is will any VFD work my Desk CNC controller or do I need to buy a new controller?
    Thank you
    Gary
  5. #53
    Mar 2003
    If the DeskCNC board outputs PWM, then you'd typically use a speed control board that converts PWM to a 0-10V analog signal, and use the analog signal to control the VFD speed.
  6. #54
    Jun 2017
    So does the speed control board get installed inside my control panel or is it a stand alone unit that sets beside the VFD?
    Do you have any recommendations on a speed control board that would work?
  7. #55
    Mar 2003
    It should be with your DeskCNC board.
    I can't say for sure that this will work with your DeskCNC board, but something like this:
    https://cnc4pc.com/motion-control/sp...trl-board.html
  8. #56
    Jun 2017
    I have 2 photos of desk CNC information sheets that I can seem to get uploaded, but from the link you sent it appears I need to use a parallel port, but my Desk CNC doesn't have parallel port on it.
    Attached Thumbnails Attached Thumbnails My router went today on my old DIY table need advise-20180112_205332-756x1008-jpg   My router went today on my old DIY table need advise-20180112_205355-756x1008-jpg
  9. #57
    Jun 2017
    Maybe the attachment process did work
  10. #58
    Mar 2003
    Sorry. This one is what you'd probably want.
    https://cnc4pc.com/catalog/product/v.../category/183/
  11. #59
    Jun 2017
    Ok thanks so I read that I need to use an RJ45 connection to attach to speed control board to the Desk CNC. Where do I find the cables or do I have to get one made? I see where the RJ45 connects to the speed control card but I can't see where the other end of the RJ45 connects to the Desk CNC controller card.
    I'll have to talk to Bosch Rexroth again. Steve told me the Bosch won't work with PWM.
    Thank you
  12. #60
    Mar 2003
    Cut the end off a network cable, to connect to your DeskCNC board. I think you only need 1 or 2 of the wires. (PWM and ground maybe?)
