Originally Posted by
NIC 77
He started out with Nema 34s but then changed to 400W servos. He wouldn't be able to get those super fast accelerations with steppers. Those weights sound a bit low to me, perhaps that is without all the motors, etc. You could always ask him, he still checks his thread. I asked him a couple questions not too long ago.
On my build, I am using a moving gantry, the gantry will weigh about 800 lbs when all done, but that includes everything, z axis, motors, etc, everything that moves with the gantry. With two Nema 34's 960 oz in low mH motors to drive the gantry using 10mm ballscrews I am aiming for around 0.2G acceleration with a max speed of 300 IPM. 0.15G would be just fine for my purposes probably. With a servo driven belt reduction I could get much faster speeds and acceleration. But you also have to look at the critical speed of the ballscrew.
The weight isn't so much of a problem as you might think. Choosing the right pitch of ballscrew is more important than a few extra pounds. I can easily slide my gantry back and forth with one hand in it's current 400lb configuration (not finished yet). As long as it's level it's not a problem. It's the 100 lb spindle and heavy Z axis that really add the weight to my build.
For the Z axis, if you get too heavy, you'll need a pneumatic counterbalance.
I'm not suggesting you copy exactly what someone else has done, but the two examples I mentioned are finished and have proven that they cut aluminum well. Both examples also use some kind of filling, epoxy granite, or what not, and have internal ribs in the structure. One has bolted aluminum plate and the other has welded steel plates for the gantry. You may choose to do something that is easier to build.
What is your experience level, have you built a CNC before? Do you have welding equipment, etc? What size of a machine are you building?
If you are unsure about what to do, you can always do a design log first to ask for advice. As you have seen, much can change during a design log.
