Newbie Is it at all possible to build a metalworking CNC router out of aluminum profiles. - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: Is it at all possible to build a metalworking CNC router out of aluminum profiles.
  1. #41
    Jan 2008
    Default Re: Is it at all possible to build a metalworking CNC router out of aluminum profiles
    Been a while since I've bought steel but that price seems reasonable, particularly if you can buy per metre (not by the whole length).
  2. #42
    Jul 2008
    Hi, all.
    Can I get in on this?
    I too built an extrusion frame router and am not happy with it's stiffness. I wanted to machine Al, and it does, if you go slow. So I am going to build a new frame and move all the motion parts over. I have some Questions about how to proceed. I don't want to hijack this thread!
    Ben
  3. #43
    May 2005
    Quote Originally Posted by Mr. Ben View Post
    Hi, all.
    Ben
    Hi Ben.
    If you want some help create another thread. In this case though you just highlight a common result that people get when trying to build a router for Aluminum machining. That is a machine gets built that doesn’t mechanically meet the users needs.
    So your post offers a good point for the original poster to consider. He really needs to consider mechanical stiffness.
  4. #44
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hello Mr Ben - Many threads in here cover upgrading routers to be able to cut aluminium. Most upgrades do not get there as the basic machine does not have the potential for the required stiffness, as you have found out. So its a start again process. If you start at the gantry most calculations take you to something like a 200x200x12mm thick aluminium extrusion or a 200x200x6mm steel section. Its better to be bigger in steel a 250x250x6mm is good. Then everything has to be scaled from that. Here's my thread on designing a router for aluminium. "Routering" actually milling light metals is quite a step up for a machine from soft materials. Peter
    https://www.cnczone.com/forums/austr...ml#post2337406
  5. #45
    Quote Originally Posted by peteeng View Post
    hi Peter do you have your router design for sale?
  6. #46
    Jul 2018
    dum dum
    Hi Loks - Pricelist is here thru link at bottom of page. https://cncrouterkits.com.au/maximus...ty-cnc-router/ Peter
