In that second photo is there another bearing outboard of the large belt sprocket? The one bearing visible is certainly not sufficient. The belt should also be the full width, as large as possible. I also cannot see provisions for tensioning the belts unless the shaft and shaft support bearings are slid along the tslots, at least in first photo.
