Concept Design for a new 6-axis router - take your best shot! - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 52
Thread: Concept Design for a new 6-axis router - take your best shot!
  1. #37
    Gold Member
    Apr 2004
    Oakland CA USA
    Default Re: Concept Design for a new 6-axis router - take your best shot!
    Quote Originally Posted by CutMasterCNC View Post
    Yes I have used it with a 2 hp router and a 5 hp spindle. That is why I had to legthen the plates from 6" wide to 12". With the six inch plates it tried to lift a little under heavy pressure from the router and spindle. Now even when I get to aggressive with a cut something else gives ..tool bit .
    I would expect that, since tool bits - especially small carbide ones - are pretty sensitive to chatter, which a machine with less than optimum rigidity will exhibit when the cutting forces build up. Your design looks good for a plasma cutter, but if you want a router too, that might require another build.
    Andrew Werby
    Website
  2. #38
    May 2011
    I like the simplicity of your design.
    I've never seen stainless used for a CNC. I have to think it's not needed.
    It's not the way I would do it, simply because of ground heave.
    The house I live in shifts a bit every now and then, a couple doors are hard to close when the weather shifts, and then mysteriously fix themselves a few days later. Probably only a few mm difference, but it does happen. Not sure if it's a huge issue.
    You know what, I was looking around online the other day, and I did see some used industrial robot arms for 5K. I can't remember where.
    I think I just realized that I should have gotten myself a used industrial robot arm and vertical rotary axis instead of building my current 4 axis build that I am working on. Ouch. I hate those kinds of realizations.
    Robot arm and rotary would be pretty cool.
  3. #39
    Gold Member
    Apr 2009
    Quote Originally Posted by NIC 77 View Post
    Yes you can use this to run it...
    https://www.rapcam.eu/
  4. #40
    Gold Member
    Apr 2009
  5. #41
    May 2011
    Quote Originally Posted by louieatienza View Post
    Hi Louie,
    Nice to see you.
    Looks very nice and only 150 Euros per month
  6. #42
    Gold Member
    Apr 2009
    Hi Louie,
    Nice to see you.
    Had a rough last 6-8 months...
    150E/month is not too bad if you can run your machine on a regular basis...
  7. #43
    Gold Member
    Apr 2004
    Oakland CA USA
    Thanks, Nic! I hear you about the ground heave, but that would require adjustment on any machine that was placed on the ground. I figure that if I notice anything like that, I'll deal with it using the threaded rods the main rails are mounted on. I'm not sure about the stainless either - it''s a bit stiffer than regular mild steel, but it's also harder to work with, not to mention more expensive.
    Robot arms are great for milling foam, but it's hard for them to deal with much harder materials, since the leverages all work against them, so they have to built very massively to counteract that. That said, I've seen them used successfully for cutting stone, but that's a different process from cutting wood and aluminum; it's more like grinding than cutting with a fluted tool.
    Andrew Werby
    Website
  8. #44
    Gold Member
    Apr 2009
    Quote Originally Posted by awerby View Post
    It is cool, though, to watch!
    I like the A-B-C head design of F Zimmermann, though I wonder how feasible it would be to DIY. What CAM do you plan to use?
  9. #45
    May 2011
    Quote Originally Posted by johncarpenter View Post
    It is unclear what the fore and aft spacing is between the bearings that attach the gantry to the rails on the bed. Spacing looks narrow. The more space between these bearings then the better the moment resistance of the gantry to tilting forward or aft.
    I agree with that. Looks like it's missing some parts. Should be a triangle structure to the front bearing that should be out in front of the gantry for a good "stance"
    The Z axis, which also has a 1" pitch screw, will be driven by a harmonic drive, according to the current plan; I was hoping that the gear ratio would be enough to keep it from backdriving and falling to the table when the power's turned off. I've got these little harmonic drive units already (Hi-T Drive servo actuator RH-14-3002-E100AL-SPA822) but haven't determined what the reduction on them actually is. Would 100:1 really be too slow, with a servo motor and a 1 pitch screw?
    Hmmm, I can do some math on that if you can figure out what the gear ratio is and the inertia of the harmonic drive, and the servo (should be published in the manufacturer literature) and the torque vs speed curve for the servo. Off the top of my head, yes, 100:1 would not work, but these things come in all kinds of ratios, like 3:1 or 5:1 or 10:1.
    So looking at the basics, if your servo was spinning at 3000 rpm, and you had a 100:1 gear ratio, that's 30 rpm for the ballscrew. I assume you mean 1 inch lead ballscrew, that's 30 IPM speed, really slow, but the big problem is the acceleration. Because the acceleration of the screw will be 1/100 of the acceleration of the servo, and the servo must now contend with the input inertia of a harmonic drive at the same time. Like I said, I can do the math on it if you want, I'd just need more info.
    If you're looking at the gear ratio to prevent backdriving, I think you should also consider wearing out your ballscrew. Your Z assembly will be quite heavy, I don't see a good way out of using a pneumatic counterbalace for it.
    So what kinds of speeds do you want your Z to move at?
    There was an interesting suggestion in the carbon fiber gantry thread, about pre-tensioning the gantry with interior cables running from the top corners to the middle of the bottom. I've seen that done on some cranes, and I wonder how much that would help with the sag problem pointed out above, also how to implement it without having it get in the way of the moving parts. Perhaps it should have that plus another steel cable that goes from the bottom to the top, so the beam can be pre-tensioned without distorting it. Has anyone done that before? I have decided to go with 10" high beams instead of the 8" ones in the original design, and will be looking for a Galil controller so I can try Jim's new system.
    It's pretty easy to calculate the deflection of a tube with a point load in the middle, once you know what your gantry assembly will weigh. I believe it will be very small, even with a heavy gantry. 10" high beams, what wall thickness, did I miss it?
    I believe the mori machines do some kind of pretensioning, some patented process, to eliminate any sag, I read that somewhere, never did figure out what it is exactly.
    How are you planning to level the surfaces you mount your rails to on your two long gantry supports? Do you have a place that will machine them? If you use epoxy leveling on each beam, you know you could always mount a weight hanging below each beam (in the center) equal to half of the gantry weight (including Z axis, etc). Now when you take the weight off, the center will be higher by the same amount the gantry will deflect it downwards when it is in the center position.
    Total overkill I think, just use the big beams and you'll be fine.
    Yep, I would also try Jim's new system if using servos. Are you going to use linear encoders?
    Unless it comes flatter than mild steel, I don't see it being beneficial, but that's just my opinion.
    For other machine designs, It really depends on the weight and geometry of the machine as to how much it will flex under it's own weight if it's susceptible to changes in the floor. I think yours is particularly susceptible, but I'm not an expert on ground heave. You have designed some adjust ability into it, so, I really don't know. I also don't know how much flex you will get in the threaded rod. I like the adjustability but I'm not really keen on those rods for some reason. I don't really have a better suggestion though.
    It depends on the robot arm. I'm talking about an industrial robot arm. I just watched a video on Youtube of one cutting hardened steel. But it was painfully slow. I also watched one of a robot arm cutting aluminum. Also very slow. But it did a good job. Clearly there are advantages to traditional machine designs vs robot arms or they wouldn't still be making them.
    What are the advantages of making a 6 axis vs a 5 axis machine? I would think the 5 axis (including rotary) would be easier to make and could cut any shape you could think of?
    What do you plan to cut with this, what materials I mean?
    The way your 4th axis is mounted to the floor isn't adjustable for heave like you are talking about for your long beams. Perhaps it's not a problem anyway.
    I like the simplicity of your design, there are many things I like about it. I see it being a big project, alot of work though to finish the design, and build. Very ambitious as was mentioned. It seems like uncharted territory, very risky to travel there, but also could be very rewarding. Have you seen any other DIY designs like this?
    Oh, and here's another robot arm I found on YouTube:
  10. #46
    Gold Member
    Apr 2004
    Oakland CA USA
    [That's a good idea; I'll have to mess with my CAD model to see how it looks, but it doesn't seem unfeasible.]
    [Yes, I've resigned myself to using those actuators to position the 5th and 6th axes, where speed isn't much of an issue but holding torque is. I need to find something else to slow down the XYZ servos which has a more reasonable ratio, but doesn't add backlash. I'd like to get XY rapids of 1000 ipm if possible, and it should be, I think.]
    [Backdriving is definitely a concern with the 5th and 6th axes, since they need to hold a heavy assembly with a lot of counter-leverage. But I didn't think the Y axis ball screw would have any particular wear issues, since it's a fast screw (1" pitch), and the Z axis screw will be similar. Why the concern?]
    [I was resigned to that; the gas springs I've implemented work pretty well in a couple of my other machines.]
    [It needs to have good acceleration, but ultimate speed is less of an issue, since Z axis moves are usually pretty short. 300 ipm or so should be fine, if it's responsive.]
    [I'm dithering between 1/4" and 3/8" wall thickness on the X axis beams; I'll probably go thick, since they won't be moving once they're in place. The gantry beam can't be that thick, though.]
    [I'm still considering using steel cables to pre-stress the beams, just hoping they won't add weird twists. ]
    [Another good idea, thanks. My only concern is that it will complicate the mounting of my racks, which is complicated enough as it is. I was planning on epoxy to make flats for the X and Y axis rails; nobody in town has a grinder that is long enough for X, and people tell me that machining on the hot-rolled tubes will distort them anyway. ]
    [I was hoping that would be the case...]
    [No, it seems like overkill; I'm not making aerospace parts on this thing.]
    [Stainless is supposed to meet higher straightness specs than hot-rolled steel - it had better, for the price...]
    [I've seen freeways held up by similar systems; I don't see them flexing much in compression.]
    [Most people aren't making very complex parts, so robot arms might not justify themselves in most cases. I admit to being intrigued by the things, but frankly they frighten me. I've had runaways on other machines, but while they tried to tear themselves apart, they didn't have the opportunity to whack me upside the head...]
    [It has to do with what the tool can reach. If you can only tilt the head back and forth, you can reach sideways undercuts but not ones on the front or back sides; that requires swiveling the tilted head around 90 degrees. I want to be able to cut natural shapes with random undercuts all over them.]
    [Wood mostly, also plastics and foam. I doubt it will be rigid enough for aluminum once the 5th-6th axis head is installed, although without that it might stand a chance. I'd also like to try cutting marble with it, if only to see if I'm right about the rigidity required for that.]
    [I haven't actually noticed the concrete floor moving around, although I suppose it's possible. I have observed some seasonal shifting elsewhere in the neighborhood as the clay layer underneath gets saturated and dries out. It might not hurt to mount the rotary table on rods like the beams get.]
    [Thanks, and yes, it's definitely going to be a challenge pulling this off - but how else am I going to be able to have the capability to make whatever-the-heck-I-want?]
    [Not really, although I've absorbed a lot from reading posts here for the past decade or so and incorporated some of those ideas. It's more similar to some large-scale Chinese machines I've seen, like this one: http://image.made-in-china.com/43f34...es-Pillars.jpg
    Love it! (could use a little fine-tuning, though...)
    Andrew Werby
    Website
  11. #47
    Gold Member Jim Dawson's Avatar
    Dec 2013
    As I recall my Z axis lead screw is 3/4 inch x 0.25 or 0.375 pitch. About 3:1 ratio, maybe 4:1. The assembly probably weighs about 100 lbs or so. But it is driven by a NEMA 34 stepper, so has pretty good power off holding torque. It doesn't drift when powered down. A MultiCam I worked on had a spring applied electromagnetic brake on the Z servo.
    Jim Dawson
    Sandy, Oregon, USA
  12. #48
    Gold Member
    Apr 2009
    One "problem" is that when doing something like finishing pocket walls that have draft with swarf milling, unless you have an infinitely positionable C axis (rotating about the Z) the machine slows down as it exits a corner, which would always invariably leave a "tell" or defect in the finish - the head has to eventually "unwind" and as it does so it dwells in the corner. When you have a 3-axis head, the tool can basically fly around that corner. Having CAM that can control this, however, is another story - or the control converts A-C moves into A-B-C moves, just the way certain programs can convert 3-axis g-code into 5-axis.
