Probotix Nebula vs CNC Router Parts CRP4848 - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 38
Thread: Probotix Nebula vs CNC Router Parts CRP4848
  1. #13
    May 2012
    Yeah. Except for their astounding QC issues and customer service problems. Anyone considering should take the time to read up on FLA
    Quote Originally Posted by manofmanyhats View Post
    This is a MUCH better machine than the other 2 you're considering OP. It will be orders of magnitude more rigid and capable of running without adjustment for quite some time. They also currently have a 25% off sale on this machine with free shipping. I don't think you're going to find anything that competes with it, short of looking at the used industrial market and waiting for the right machine to come along. The CNCRP PRO line is also very nice, but the FLA Saturn is likely considerably more rigid, as it has a welded steel frame.
  2. #14
    Gold Member LeeWay's Avatar
    Jun 2004
    Default Re: Probotix Nebula vs CNC Router Parts CRP4848
    I don't think having just the lower frame in steel makes it any more rigid than aluminum. It still uses an aluminum gantry and beam, so that is where steel would make a difference. It is no more rigid than the CRP pro version.
    Plus the bracing on the gantry is just awful design wise. At least the two in the OP have decent designs.
    Lee
  3. #15
    Mar 2013
    Quote Originally Posted by LeeWay View Post
    You don't think the linear rails on the FLA are far superior to either the probotix's (the gantry on which seems a little whimpy to me too) or the standard cncrp (which the OP referred to)?
    edit: I don't think any of them are bad machines, just that for around the same price, I find the FLA superior. Personally, I would save up for a CNCRP pro 5x10 though
  4. #16
    Jun 2004
    Yes. Better than the two in the OP.
    No better than the CRP Pro with profile rails too.
    That said I have not read the ball screw specs on any of them. They may or may not be better than the R&P on the CRP machines. I use the older style CRP pro with the v bearings and it along with the R&P is plenty accurate for our needs. It is a stout little machine.
    Lee
  5. #17
    Jun 2017
    Out of curiosity; would the Pro version or FLA model add any additional machining capabilities? ie AR lower?
  6. #18
    Jun 2004
    I would not think either would be strong enough or accurate enough for that. Either would probably machine aluminum easy enough, but my understanding is you need some long tooling to machine those things. Just a WAG on my part. I haven't tried it.
    If either had a steel gantry and risers, then you might be closer to the rigidity required.
    Lee
  7. #19
    Gold Member
    May 2005
    I suspect that most of the lower end routers out there would have an issue with AR receiver machining. Rigidity is one issue but you also have to deal with the need to drill at reasonably low spindle speeds. Plus you really want a coolant solution
    Quote Originally Posted by DG_TX View Post
  8. #20
    Jun 2017
    In that case, if I only stick with wood projects does the difference in rigidity between a pro and standard make that much of a difference to warrant the cost difference?
    Btw, I'm planning on purchasing a spindle instead of a router.
  9. #21
    Registered Biggs427's Avatar
    Feb 2016
    Don't FLA have gantry made of steel now? My memory might plays me tricks but I think I've seen it pass in the FLA section.
  10. #22
    Mar 2017
    Quote Originally Posted by Biggs427 View Post
    Yes the new models are steel , as well as some other upgrades
    I don't actaully know anything about CNC router tables , but I stayed at a Holiday Inn Express last night
  11. #23
    Mar 2013
    I didn't realize the gantry was now made of steel tubing too. Seems like a really nice kit at that pricepoint if all of the QC issues have been worked out, though personally I think I would kick myself for not getting something larger (I'm still tinkering along with my own DIY 2'x4' machine)
  12. #24
    Mar 2003
    Yes. And in addition to the increased rigidity, you'll also get much smoother motion.
    Also, the rails on the standard are not very tolerant of dust on the rails, with many users reporting binding if dust gets on the rails. The linear bearings on the Pro are unaffected by dust and chips on the rails.
    And the linear bearings on the Pro will last a lifetime.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
