New Machine Build D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome )
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome )
    May 2016
    Syrian Arab Republic
    Default D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome )
    Hi every one
    I plane to build my second D.I.Y C.N.C
    the Machine I Plane to Work With MDF LEXSAN .... etc and I hope It will by Strong enough to work with aluminum
    Machine Size 1300X800X150mm
    for aluminum extrusions Size 60X60
    Motor X , Y Nema 34
    For Z Not Select yet
    ball screw RM1605
    Rail
    X : railsSBR16 With nut housing SBR16LUU
    Y : railsSBR16 With nut housing SBR16uu
    Z Not Select yet
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-4-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-1-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-3-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2-jpg
    May 2016
    Default Re: D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome )
    photo for aluminum extrusions
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-13-55-22-jpg
    May 2005
    Once you start talking about doing Aluminum you need to think far more robust machine design. Id discourage round rails and Aluminum extrusions.
    If you insist on extrusions id suggest the largest you can find for the gantry. Ideally the gantry would be a large square steel beam. In either case you need to look closely at the vertical supports for the gantry beam, flat playes dont cut it unless they are very thick.
    A hybrid approach would be a steel gantry beam assembly riding on top of an Aluminum framed machine. This is a workable solution that addresses the common weak point in a routers design. That weak point is often the gantry / z axis.
    Note that much of the above depends upon your expectations. If doing aluminum means engraving to you then you might get by with a low end approach. However if your idea of doing Aluminum is similar to other sheet goods id seriousl lean to a more robust machine.
    May 2016
    Quote Originally Posted by wizard View Post
    Thanks for your advise
    1- the machine i'm already start work with aluminum extrusions
    2- I'm still thinking about z axis all axis are first I put round rails in my design then I read alot of review about round rails and most people was not too much happy with it so I decided to use Linear Rail Guide entil now it's OK
    then I read If I want the Z axis rigid There is Double Nut Ball Screw then I now If I put Bigger Size of Ball Screw it will better so I still Confused About The Z axis
    May 2016
    Some Update
    The Sheet Metal For Y axes Just for Test Because I Still Waiting for SBR16LUU
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-12-36-39-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-12-36-33-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-12-36-05-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-12-37-10-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-12-37-26-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-13-12-36-18-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-06-14-13-29-36-jpg
    May 2005
    Quote Originally Posted by yamanmax View Post
    OK
    I'm not wedded to the use of profile rials, round rails can be useful in a proper design and if the builder understands their limitations. At some point though it just makes sense to use the more robust solution which Is profile rails.
    What you need to be careful about is that the rails are long enough to meet you work area requirements. Your design seems to constrain the saddle movements which might be a problem. Basically you need enough travel to cover your expected work area with the largest cutter you intend to use. That means you need to account for the saddle widths. Right now your Y axis seems to be especially constrained.
    Double nuts are one way to eliminate backlash in a mechanical system. Generally you want to get as near to zero backlash as possible. On the other hand larger diameter lead screws address stiffness needs which is another matter altogether.
  7. #7
    Member Chris D's Avatar
    Apr 2005
    Just a quick thought and comment on your design / build.
    The side plates appear to be very thin - almost looks like galvanized sheetmetal in the photo. Without additional framing, these side panels, which support everything above the table are a prime area of problems. They simply would not be stiff enough to provide rigidity for anything above basic engraving. The side loads (along the 800 mm axis) would cause substantial flexing on those panels.
    Seeing that X axis is 1300mm I have a rough idea of the scale of the machine. In my opinion, you should be using about 13mm thick aluminum plate. I have a machine similar in size with 10mm side plates on the gantry and it is marginal at best for heaving cutting in hardwoods, have not attempted milling aluminum yet.
    Chris D
  8. #8
    May 2016
    Quote Originally Posted by Chris D View Post
    Chris D
    thanks for your quick replay
    yes you are correct it's sheet metal galvanized 2 mm because as I mentioned in last post
    ( The Sheet Metal For Y axes Just for Test Because I Still Waiting for SBR16LUU)
    I will put Aluminium plate 6061 25.4 mm THK
  9. #9
    Apr 2005
    Ah, very good!!!! Beyond that, your design looks robust, it should be a good performer.
    Chris D
  10. #10
    May 2016
    The table Legs has arrived from China
    Now I Can start work With Table
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-07-02-15-52-08-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-07-02-15-52-16-jpg
  11. #11
    May 2016
    table adjust leg after I make the Plate and attache with the table
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-07-13-14-51-32-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-07-13-14-51-36-jpg
    for legs I bought from alibaba
    https://yava.en.alibaba.com/?spm=a27...394.0.0.kBNUD5
    The model Number DGT100-20100 price 10$ without Shipping
  12. #12
    May 2016
    New Update for Y Axis
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-07-26-18-58-28-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-07-26-18-58-48-jpg
  13. #13
    May 2016
    Some Update
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-10-18-25-08-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-10-18-25-18-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-10-18-25-39-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-10-18-25-51-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-10-18-25-58-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-10-18-25-30-jpg
  14. #14
    May 2016
    finally finished the mechanical Part
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-30-15-56-57-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-30-15-56-52-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-09-30-15-56-47-jpg
  15. #15
    Looking forward to some video of it running!
  16. #16
    Apr 2015
    wow, thats a lot of reinforcement extrusion and plates in the frame of this thing. 30mm Hiwins are going to be overkill on your Z too, so you should have no issues with aluminum once your gantry plates are made from 1/2" or more aluminum instead of sheet metal.
    Luthier/Woodworker/Machinist in NS, Canada.
  17. #17
    May 2016
    Quote Originally Posted by jahnj0584 View Post
    I'm still not sure until I test it
    but I hope so
  18. #18
    May 2016
    Quote Originally Posted by fretman_2 View Post
    SURE
  19. #19
    May 2016
    cable chain finally arrived .
    now I can work with the control unit
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-11-02-16-03-07-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-11-02-16-02-59-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-11-02-16-03-18-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-11-02-16-04-57-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2017-11-02-16-03-27-jpg
  20. #20
    Apr 2009
    NICE!
