New Machine Build D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome ) - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome )
  1. #21
    May 2016
    Syrian Arab Republic
    Default Re: D.I.Y C.N.C router aluminum extrusions ( All Suggestions Are welcome )
    working area
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-5-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-6-jpg
  2. #22
    May 2016
    almost finish still have to work on cable management and some works with sensor
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-05-18-31-36-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-05-18-31-53-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-05-18-32-56-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-05-18-33-06-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-05-18-33-13-jpg
  3. #23
    Great looking machine...that control station looks like something from a 60's sci-fi movie! Awesome!!
  4. #24
    May 2016
    Quote Originally Posted by fretman_2 View Post
    thanks
  5. #25
    May 2016
    Today I worked with cable management and as you can see in picture I don't calculate the length for cable chain correct so I think I need more about 250mm for X and Y and so I order 1 meter, but the problem it will arrive between 27 FEB and 20 MAR
    so I Think from now and until the Cable chain arrive I will WORK WITH SENSORS AND OTHER thinks
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-07-18-29-02-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-07-18-29-40-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-07-18-29-17-jpg
  6. #26
    May 2016
    last week I install the limit switch and connecting Pc to Mach 3
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-20-17-12-56-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-20-17-11-12-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-20-17-17-54-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-20-17-12-51-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-20-17-12-45-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-02-20-17-13-09-jpg
  7. #27
    May 2016
    Last week i put the main Plate for Bed it's aluminum 10mm THK Then I try To alignment the spindle For horizontal it was not hard just tie the secrow a little bit the push the spindle in opposite direction and read the indicator
    for vertical side I think i'm to far about 0.25++ mm so if any body have any idea how to alignment the vertical side for spindle please help
    I try to put shims but it's not give good result ( it to match or not enough )
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-03-11-19-01-03-jpg
  8. #28
    Member awerby's Avatar
    Apr 2004
    Get a feeler gauge set Proto to sacrifice; it will give you various thicknesses of shim in the range you need.
  9. #29
    Member Biggs427's Avatar
    Feb 2016
    When I'm tramming my router, I cut shims in aluminium beer can and finish with cooking aluminium paper foil.. The beer can is 0.004 thick and the foil is roughly 0.0007.
    Not as precise as awerby's solution though
  10. #30
    May 2016
    Quote Originally Posted by awerby View Post
    many thanks yesterday I bought Blade Metric Feeler Gauge Set.
    I put 1 mm and it's look good for me now .
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-03-14-19-25-20-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-03-14-19-25-38-jpg
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-03-14-19-25-20-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-03-14-19-25-38-jpg
  11. #31
    May 2016
    Last 2 weeks I make some test
    and finally I can say the machine work stable
  12. #32
    May 2016
    first complete Test with aluminum
    I use End mill 6 mm 2 flute and end mill 2 mm for small corner
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-05-12-18-08-48-jpg
    D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-05-12-18-09-12-jpg
    Attached Thumbnails Attached Thumbnails D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-05-12-18-09-12-jpg   D.I.Y C.N.C router  aluminum extrusions ( All Suggestions Are welcome  )-2018-05-12-18-08-48-jpg
