New Vertical CNC Router Build
Results 1 to 6 of 6
Thread: New Vertical CNC Router Build
    Jun 2017
    Default New Vertical CNC Router Build
    I am super excited that I found this forum as I am thinking about building a Vertical CNC Router, similar to the Moslow CNC. I am looking at purchasing this kit from Aliexpress,
    I am wanting to cut 12mm ply, 2400mmx1200mm sheets. Can anyone tell me if this kit is suitable/over kill / or not suitable?
    Thanks in advance and I'm sure there will be many more questions to come.
    Dave.
    Feb 2011
    Default Re: New Vertical CNC Router Build
    for a big table i would be looking a lot more upmarket than this set
    very small motors low end driver and low voltage power supply
    are u using rack and pinion?
    Big table like that would not be good with cheap skinny ballscrews
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    No, not without knowing exactly what you're building, and what performance you expect to achieve.
    The best way to throw money away is to buy motors and electronics before you even know what you are building.
    UCCNC 2017 Screenset
    Apr 2009
    Quote Originally Posted by ger21 View Post
    It's actually a pretty cool idea, using rope or cable with pulleys. It's not fast by any means but likely very inexpensive to build.
    Member Tutu's Avatar
    May 2017
    United Kingdom
    Nema 17's are 3d printer steppers they have no place in a 8*4 setup, nema 23's are the minimum that kit is oddly specced.
    Registered Ryadia's Avatar
    Apr 2017
    Seriously?
    Do you know the power rating of the transformer? It might run those little steppers on a small machine but something 2400mm long is going to test the durability of any stepper with power from a transformer that can't supply the maximum voltage the steppers can handle. Take a tip and check out what Homann Designs in Highet Victoria has to offer. You'll pay more than the Chinese stuff but you get gear that will take the stress of cutting very large sheets with complex designs and I can testify to his after sales service... Something you can't expect if you buy from anyone who doesn't speak your language and expects you to pay return freight when you burn the motors out, only to be told you overworked them and there is no warranty. BTW. I'm only a Homann customer, Ive got no other connection with them.
    Ryadia
