You did a pretty good job for being new to fusion 360. I didn't look closely at your design but It looks pretty good and it looks like you are going to use CNCRP components in the key areas? Just one recommendation, use double anchor- counterbore connections or similar to join your extrusions where they meet at right angles. Its the strongest connection method you can use and it pulls your structure into square. As long as your extrusion ends are cut squarely.
