So I got a good deal on a used mydiycnc Bigfoot, but I'd like to replace the cheap rotory tool with a small porter cable router. does anyone know where I can get mounting brackets and if this would too heavy or not? thanks.
You only need 2D CAM for that... we call that 2.5D, pocketing and profiling. A dado is just a cross-cut groove, and a rabbet is just a groove on the edge of a board. Doesn't take too much creativity to use 2D toolpaths to achieve these cuts. I even found a way to do dovetails using 2D CAM laying parts on the flat.
You'll only really need 3D to do surfacing, such as bas relief carvings and such.
