Originally Posted by
louieatienza
For the size of your machine, a fixed gantry may be the better choice, for the obvious reason that it's fixed. If you're going for cost-effectiveness/strength, you'll blow your budget with CF. While steel is heavier, generally weight will increase the resonant frequency of the machine, which should lead to less vibration. If this were not the case, VMC builders would make their machines with CF mostly, because they could use smaller servos and linear bearings.
While the Steel reinforced CF plate my be stiff, it still would be subjected to torsion/twist when you are cutting at the extremities of the cutting area. You would mitigate that by increasing the distance between your bearing blocks on the gantry legs, which would increase the width of your transverse plate. But then you'd also need to increase the length of that axis as well to have the same cutting area. Also, all THK profile rail/block are not equal. They have an interchangeable type, which has almost no preload (no designation), light preload (C1), or medium preload (C0). Obviously, the C0 would give you less gantry leg "translation", but that will cost you in terms of the extra torque needed to move that axis (in addition of the torque needed to overcome the friction of the anti-backlash leadnut, weight of the axis, and even detent torque of the stepper). Of course the slower you cut, the more torque you'll have available, but if your plan is to mill aluminum you'll need some speed to achieve a good finish.
Those larger torque numbers is more an indicator that the axes on these mills are a LOT heavier, and you need to also overcome the stiction that comes with dovetail ways. And yes, milling harder materials with lower-speed high-torque spindles requires more holding power. Aluminum on the other hand cuts relatively easily. I've had success cutting aluminum with an even wimpier setup - 425in-oz steppers running 1/2"-8, 8 start leadscrews and G540 at 48V, and still cut aluminum at 60ipm with good finish. With a wood frame CNC. Almost 8 years ago! Knowing how to work your machine to the limit, and then backing off for the finish cut, helps. Also, I discovered the use of high-speed (constant-engagement) toolpaths actually benefit our more flex-prone DIY routers. I bought in at the time to a mid-level CAM package early on, but nowadays, Fusion360 makes this available to everyone.
So I wouldn't worry about the steppers, as long as you have a spindle with decent power. The limits to your surface finish are going to be with your ACME screws, because of the way they're made. Unless you have a precision ground set, they'll have very slight fluctuations in lead and stiction that will translate to your work. The acetal AB nuts help smooth that some, but they're no match to even cheap ballscrews.
Again, weight used judiciously can be your friend. Here, because your axes are relatively small, you don't have to worry about making it heavy; I doubt that it will be too heavy for your motors to move. Again, I used 425in-oz steppers with a G540 at 48V. Those steppers are capable of higher speed with more voltage, and I don't have the mechanical advantage of a finer leadscrew pitch (I basically had 1tpi or 1" lead leadscrews.) Still, I moved an 85lb+ gantry with two screws and two steppers, at 750ipm, and cut at 200ipm. And I was able still to resolve fine detail like 1/64" serifs on raised lettering. (I did scale it back to about 400ipm rapids however.) Good enough for me. CarveOne made a large 4 x 10 table moving a 250lb gantry with two NEMA23 steppers, at high speed. Gives you a little respect for the kind of forces these small motors generate...
