Video Got my 1st cut done!!! :) :) :)
Results 1 to 6 of 6
Thread: Got my 1st cut done!!! :) :) :)
    Jan 2014
    Default Got my 1st cut done!!! :) :) :)
    May 2005
    Default Re: Got my 1st cut done!!! :) :) :)
    Nice first light.
    Feb 2017
    nice job. Can you provide some details of the machine ?
    Jan 2014
    Quote Originally Posted by junior2016 View Post
    I used this build as a guide, but ended up doing my own design: https://www.instructables.com/id/DIY-CNC-Router/
    800/500/300mm linear rails (SBR 30/16/12)
    1/2-10 5 start ACME screws w/ anti-backlash nuts. Oldham zero backlash couplers
    382oz/in steppers
    Gecko G540 w/ relay for spindle control
    Bosch 1617 Spindle (precise bits collet set soon)
    LED lighting
    3D printed cable carrier
    let me know if you need anything else specific. I plan on replacing the MDF board with aluminum drilled & tapped for a step block set, once I'm ready. The MDF is just a cheap beater to start with
    Very cool...take some pics too.
    Jan 2014
    Quote Originally Posted by fretman_2 View Post
    Got my 1st cut done!!! :) :) :)-1stcutdone-jpg
