That looks like reweld. Take a deeper cut, I routinely cut .04-.07 in 6061 at 24k RPM and 60-80ipm.
I only use pledge furniture polish for lube. No reweld occurs.
The bigger chip from going .04-.07 will get the heat out in the chip, not into the tool and work.
Also, what material were you cutting? Was it hardware store aluminum, because that is often 50 series wish is gummy as all hell.
