Accel is at 500mm or 20ips. The table still needs to be boxed in this week and should stop the slop it has in the Y direction from being bolted together along the short cross members. No I could not bring a fully welded table into my basement.
Once the machine is done ill be making a overview video and all that jazz. The 4040 rails are bolted to the table with 1/8 steel angle. If something moves, it's the whole table top due to leverage and lack of welds (42" high work surface). The feet are not moving
