[It's usually best to construct your frame first, then worry about the steppers and drivers. Things often change as you're building, and you don't want to be boxed in by your earlier choices.]Hi, this is my first post here!
I'm currently building a simple CNC plotter. At first, it's main duty will be writing with a fountain or a regular pen on a piece of paper of maximum A4 size. For the sake of safety margin and further development I would like my worksize to be 500mm x 400mm.
I plan to use linear shafts (fi 16mm) and a timing belts. Z axis would be no longer than 50mm, but for plotting purpose I think I would just use the servomotor.
Would it be later possible to modify that plotter for brass/aluminium machining?
[If you build it rigid enough, and use the right sort of spindle.]
What stepper mottors should I use? My first choice was 3 V, 2 A, 2,5 mH, 0.88 Nm but I'm not sure if 3 V, 1.7 A, 2.88 mH and 0.48 N would be ok.
I believe that for pen plotting purpose weaker motor would be sufficient, but I'm not sure about brass/aluminium.
[I'd say go with the first motor, with the least inductance and highest torque. Give it a 48v power supply and run it with drivers that can handle that much voltage and current, like the Geckodrive G-540.]
I also have a question about X axis drive. I will have only one motor driving X axis, on the one side of the machine. With my relatively small worksize, that asymmetry is negligible, and one motor would be sufficient, right?
[It would be better to drive it from the middle.]
I'm beginning to create model of my plotter now, I will upload it later, so you will have better overview of what do I have in mind.
PS As I said, this is my first post and first CNC machine, be forgiving!
