Dear All,
I would like to build my first CNC router, and as I finally decided what size it will be (based on the ballscrews and rails) I made a plan in SketchUp.
I intend to cut aluminium, wood and plastic with the machine. I don't know whether this could handle steel too, I guess not... would be nice though
I would like you to check it, and give me some feedback. Please tell me if there is anything I could improve before I build it. I haven't bought any extrusions nor aluminium plates, nor square tubes yet, so the design may change if necessary.
About the components (all Chinese stuff):
- steppers: 4 pieces of Nema 23 425 oz in
- spindle: 2.2kw water cooled
- ballscrews: SFU1605
- linear rails: SBR20
The X axis (so the longest one) has 2 ballscrews, which are 1180mm long each, the linear rails are 1300mm so the travel length with this design is a little over 1000mm (~1018mm in SketchUp). On the linears I have 2 SBR20LUU bearings, so they are the longer versions, between the 2 bearings there is 82mm, so the total length of the gantry side is 274 mm (96mm + 96mm + 82mm). The rails and the ballscrews are attached to a 40x80mm aluminium extrusion.
The Y axis has a 1050mm ballscrew with 1000mm rails 212mm apart from each other with normal SBR20UU bearings. The distance between the bearings is 60mm, so the overall width of the Z axis plate is 160mm. This gives me about 800mm travel length (~828mm).
The Z axis has a 250mm ballscrew with 300mm rails, they are 115mm apart from each other, also with SBR20UU bearings. The distance between the bearings here is also 60mm, with that I get a 130mm travel length.
I designed the gantry plates from 2mm aluminium plates, although I haven't done any weight calculations yet, so I'm not sure if I should replace the back plate of the gantry with 2 40x80 extrusions, or it doesn't really matter. This seems more rigid to me
The base plate is also 2mm thick aluminium (I would like to drill a lot of holes on it and thread them). The OSB plate is just for visualizing the cut area.
The table is made from 40x40mm 3mm thick steel square tubes, welded together.
The shaft couplings are the flexible aluminium couplings, I hope they are strong enough.
I designed some covering on the X axis ballscrews, and I just made them see-through to show what there is (same with the Z axis plates).
Distance between the top of the Z axis stepper and the base plate is 635 mm.
I plan on installing proximity sensors as limit switches, and some cooling system too, not sure what though. Dust shoe for wood might come later.
I don't have any machining experience yet (I am just "YouTube-educated") so when I do something wrong, that's just because I'm a newcomer.
Any comments, questions and suggestions are welcome
