I've started attaching the cable carriers, and will need to make a few more custom brackets before everything can be finished up. Also need to make extensions for the proximity sensor wires, find and order the right breakout boards to go between the leadshine drivers and the UC300 and decide if I'm going to keep my current electronics cabinet (which is a re purposed filing cabinet, or scrap it and go with a more traditional box) Doing a good job with wiring is not nearly as straightforward as I had hoped, and is causing a few headaches.
Attachment 341594
