You will want to post some more info on the machine for any suggestions on spindle.
Mach 3 will except txt as well as tap. Fusion 360 is a good place to start.
Hi all.
Im new to this CNC, but it intrest me alot.
I have build a CNC machine and got it all up and running,Nema 34 and some laser cut parts from work..
First, what spindel should i buy? i like it big
i have tryied the roadrunner that follows whit the Mach 3 program, trial...and put a pencil to the machine and it draw it, so fare so good..
What i need help whit now, what program should i choose for a beginner like me?, to start whit i would like to cut some few DXF files, and learn from it, but i cant find any easy programs to make a .Tap file that the Mach 3 ask for..
Could use any help, allso whit links for download..
Thx again
about my build i bourght these on Ebay..
German Ship 3Axis Nema 34 Stepper Motor 1232OZ-IN,5.6A & DRIVER CNC PLASMA&MILL | eBay
and
SBR16-300/1000/1500mm linear rail set+3 16mm ballscrew RM1605+BKBF12 bearing CNC | eBay
its build in steel, and allmost rdy to run..
And thx for the fast reply, i will try download the software, and try to learn it..
Post a pic of your machine.
As Louie said, Cut2D is about as easy as it gets.
UCCNC 2017 Screenset
Got a spindel from Ebay as a set, have just mounted it..
Anyway, my Axis are sometimes stalling, and tryied for 3 days now to locate why, whit no result..
have looked trough forums here to see if more people have the same problem, and some have, my next try will be trying another computer, just to see if that works out.
And for the controller(or whats it called) whit those small white switches, i have no clue where to set em? i have set them for 3200 steps i think, and seems to be running ok, but still stalls...and for the current, i dont dare touching those switches, i dont wanna burn something of, but they are set for the higest Amps, im using Nema 34 motors
