sounds awfullt thick. At that price though, get one and see if it is worth it!
I've found some cheap screws that look as though they might be useful for CNC drives. But are they too cheap.
See picture...
Specs are
28mm Diameter
5mm Pitch
535mm length
Precision rolled
Flanged nut included
Cost £11.33 Inc VAT
Your comments please.
Stop talking about it and do it already!!!!!
Like your name "MrBean" Haven't seen him on TV over here for some time.
The problem may be excess play in the nut. This could be fixed by the use of a material here in the states called "Moglice"
http://www.moglice.com/
There's an article about it in the Jan-Feb issue of "The Home Shop Machinist".
It sounds pretty good.
Hager
I believe that Moglice is quite expensive, and I believe it would be cheaper to buy a good acme screw than to try to get the play out of a woodworking vise screw.
UCCNC 2017 Screenset
