New Machine Build Building stainless steel router
Page 1 of 9 1234 ... LastLast
Results 1 to 12 of 108
Thread: Building stainless steel router
    Sep 2009
    Default Building stainless steel router
    I'm going to build 4'x 10' cnc router. I want to make the table height adjustable. The table needs to be 6' long most of the time so the end has to fold down. And I would like to have a 12" X 48" vise on one end. I'm new to this so go easy on me.
    Mar 2003
    Default Re: Building stainless steel router
    Are you asking any questions?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Sep 2009
    I'm going to cut the table out of aluminum to make the adjustable table 4' X 5' so I can get the size to start cutting my stainless tubing. I will have to make a jig to drill screw spline in aluminum then will weld joint after bolting. At this time I' m not into it far enough to ask questions but I'm sure it won't be long.
    Gold Member
    May 2005
    Did you win the lottery or do you have another reason to use stainless steel for the machine structure? I hope you realize that working with stainless is very difficult compared to regular structural steel.
    Gold Member
    Apr 2004
    Oakland CA USA
    Could you share a drawing showing how the end of the table is somehow going to be able to fold out of the way and extend when needed? I'm having a hard time picturing this, given that none of the machines I've ever seen could do it.
    Andrew Werby
    Website
    Sep 2009
    I'm using stainless from the salvage equipment at the company I worked at. We only used stainless so I have been saving materials for about three years before I retired. When they scraped equipment I salvage as much as I could get my hands on. I was able to cut and build the 8020 aluminum table now I need to start the adjustable legs. I have a 10' stainless threaded shaft from one of are freezers that was damaged but will work fine for adjustable legs. At this time I don't have any drawings but I will try and post some pictures if I can figure out how to do it.
  7. #7
    Sep 2009
    I found 12v gear motor and power supply on eBay to drive my legs up and down. I also picked up 24" absolute scale so I can monitor height when running up and down. I have used v bearings and rails from our robot rebuilds that I will use for vertical guides. I want to make wheels to roll around in shop and screw down legs when it's parked. I will be doing a lot of lathe work today on leg screws and screw down stops hope to have a picture or two tonight.
  8. #8
    Sep 2009
    Building stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpeg
  9. #9
    Sep 2009
    I'm about done with vise and most of welding on table. I will try and post some more pictures. I don't know why they are upside down.
    ThanksBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpegBuilding stainless steel router-image-jpeg
  10. #10
    Gold Member
    Apr 2004
    Oakland CA USA
    Are you driving the screws with roller chain?
    Andrew Werby
    Website
  11. #11
    Sep 2009
    Yes the vise screws I'm using #25 and table #35 roller chain.
  12. #12
    Mar 2003
    You've got to get the pictures rotated. Looks cool, but very hard to look at.
