New Machine Build Building stainless steel router - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 101 to 110 of 110
Thread: Building stainless steel router
  1. #101
    Sep 2009
    Default Re: Building stainless steel router
    Building stainless steel router-4d8303be-013c-4968-891a-0cd86dce7a7e-jpg
    Wired up laser cross line to masso output relay along with air relay. I think this will make setup quicker. I was tired of quessing where my x,y corner location. This is probably been done a lot but just thought I would share it for what it’s worth.
  2. #102
    Sep 2009
    Building stainless steel router-0c1c0bc8-d7f4-4cdf-a7da-f461efa4e352-jpg
    Finally got tray for vacuum hose done.
  3. #103
    Sep 2009
    Building stainless steel router-f43659ef-d261-4573-b111-5b8c313bdfbb-jpg
  4. #104
    Member Biggs427's Avatar
    Feb 2016
    Quote Originally Posted by grg_p View Post
    This collector and boot looks beautiful!
    How is the suction with an "incomplete" brush?
  5. #105
    Sep 2009
    I’m very happy with it you can clearly see what it’s doing. I will try to make video if I can figure out how to down load it. Last time i tried it said file was to large.
  6. #106
    Jun 2005
    Cool Re: Building stainless steel router
    Wow, beautiful build.
    Those vacuum manifold lines look like the exhaust pipes from a Harley or something, amazing job.
    Russ
  7. #107
    Sep 2009
    They are 2 1/2 stainless car exhaust tubing from eBay. The main tube is 4” piece I had left over from air cylinder and donut is 3 90 bends.
    The hard part was cutting slots with router in the donut. There was no why to grab it so I hot melt glued to board to hold it. That worked well. The first time I fired it up I didn’t think it was going to working very well then I realized I didn’t have dust collector gate open.
    When it’s running you don’t even see chips it looks like it’s not even cutting. The air clears the path and blows the chips up in to the vacuum and since they are being blow up in the back it literally looks like it just running above the surface. I really like not having to disassemble to change bits and being new to all this I really want to see what’s going on when it’s cutting.
  8. #108
    Sep 2009
    Building stainless steel router-aef2df6a-043a-41f9-b6f3-393451a77ccf-jpg
    I down loaded spoil board cut file and cut grooves for foam cord seal. Thanks for the help jalessi.
    I wanted to seal the top so I painted rubber coating to seal and also give a nonslip surface before cutting. I’m thinking about doing the rest of my soil board as well.
  9. #109
    Apr 2006
    Very nice job, your donut exhaust is very cool. Is it open on the inside closed to the cutting side? So you just direct the air in to the chips and it stucks it up the two pipes? Nice tig welding too
  10. #110
    Sep 2009
    Building stainless steel router-8339a34d-7a2f-424e-95cc-cb800229c2b9-jpg
    I don’t use air except for metals to cool and remove chips. Wood is picked up without the aid of air but can be used if needed. Sorry I didn’t see your question.
    Attached Thumbnails Attached Thumbnails Building stainless steel router-e9b2e87f-2ae7-41fb-9a01-e5026b01736b-jpg
