New Machine Build Building stainless steel router - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 110
Thread: Building stainless steel router
  1. #61
    Sep 2009
    Default Re: Building stainless steel router
    Started mounting pinion in post. Had to cut down pinion and mount to shalf for bearings to clear rails. The belt will run inside tube and motors will be mounted above top rail. Top bearings are fixed and bottom bearings for rails are excentic for adjustment. I will mount racks to rails which will take a lot of time to get right, the rails will be positioned to bearings so they should never vary. I used the adjustable table to lift head of support posts, it work really well. I have a lot of gears and shaft to key. I have been working on a lot of other projects and it's nice to get back at it.
    Building stainless steel router-image-jpg
  2. #62
    Sep 2009
    Building stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  3. #63
    Sep 2009
  4. #64
    Apr 2016
    Quote Originally Posted by grg_p View Post
    Does your gear tooth have full engagement on the rack ?
  5. #65
    Sep 2009
  6. #66
    Sep 2009
  7. #67
    Sep 2009
  8. #68
    Sep 2009
    I don't know if this shows up well enough the rack will be between rail and bearing mount. If it doesn't make sense I will try and explain it better. Sorry not much of a writer.
  9. #69
    Sep 2009
    Mounted my rack and pinion.
  10. #70
    Sep 2009
    Started to run wires and belts
    Attached Thumbnails Attached Thumbnails Building stainless steel router-img_2416-jpg
  11. #71
    Sep 2009
    Building stainless steel router-img_2420-jpgBuilding stainless steel router-img_2420-jpg
  12. #72
    Sep 2009
    Welded up spindle water tankBuilding stainless steel router-img_2424-jpg
    - - - Updated - - -
    Building stainless steel router-img_2425-jpg
    - - - Updated - - -
    Building stainless steel router-img_2426-jpg
    - - - Updated - - -
    Building stainless steel router-img_2427-jpg
  13. #73
    Sep 2009
    Needed to mount touch screen
    Building stainless steel router-img_2428-jpg
  14. #74
    Sep 2009
    Building stainless steel router-img_2429-jpg
  15. #75
    Sep 2009
    Building stainless steel router-img_2430-jpg
  16. #76
    Sep 2009
    Laying out components for electrical panel. Getting them mounted
    Building stainless steel router-img_2435-jpg
  17. #77
    Mar 2014
    Dude, are you confident that AOD pump is going to flow enough? Not sure it's enough pump 😉
    Sent from my Pixel XL using Tapatalk
  18. #78
    Sep 2009
    I had a different pump for it but it was a low pressure high volume and the ID of the spindle fitting is only 5mm so I was afraid there won't be enough pressure and just cavitat. If it doesn't cool enough I will run cooling tubes through the tank. I had the pump laying around so if it doesn't work I'll replace it with something else but it seems to move quite a bit of water. I appreciate the questions since this is my first go at this.
  19. #79
    Mar 2014
    I use a little Rule brand pump. Like a bilge pump for a boat. The spindles don't require much flow at all to stay cool. And that AOD pump might be too high a pressure for the fittings on your spindle. Wouldn't want your coolant lines blowing off.
    Your TIG welds look great! Wish I could weld like that.
  20. #80
    Sep 2009
    Thanks for the compliment but I'm not really that good at it but it's fun to tig weld stainless. I ran the pump for 15 minutes to see what it would do and I didn't have any leaks and I wanted to check spindle for leaks to make sure there wasn't a short before I fire it up. If the pressure is to high I can always turn down the air pressure up or down if need be. The electrical will be the big challenge. My old computer donor has issues and all the wiring diagrams are in Chinese other than that all is good. I really want to get this fired up so I can start breaking stuff. My screws came in so I can finish bolting the electrical components down and start landing wires. I need to figure out what needs fuses and where. Again thanks for the replys I feel better about my pump selection now.
