New Machine Build Building stainless steel router - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 110
Thread: Building stainless steel router
  1. #41
    Sep 2009
    Default Re: Building stainless steel router
  2. #42
    Sep 2009
    I got insert for vise done today. Here are some pictures.
    Building stainless steel router-image-jpg
  3. #43
    Jun 2015
    Very clever. Great job.
    Justin
  4. #44
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I'm really impressed with how much pressure that the vise can applies and it doesn't rack
    What size threaded rods did you use for that?
    Pressure would be my main concern with that handwheel.
    How hard is it to clamp a two pieces of stock, one on each side, without having 3 hands?
    Looks really nice.
    UCCNC 2017 Screenset
  5. #45
    Gold Member LeeWay's Avatar
    Jun 2004
    I have a similar vise system in the end my old work bench that used an old work mate hardware. You have to turn two handles to clamp something.
    It works well and when I need something to sit in there precisely, I use two hand spring clamps. From there you can apply a little pressure and adjust as needed. Then final tighten. Works pretty well. I have cut box joints with it like that.
    Lee
  6. #46
    Sep 2009
    I used 1"-4 threads per inch acme rod. You don't have to put much pressure on the wheel to hold wood. It generates a lot of force. I have not tried to clamp more than one piece at a time. It holds no matter where you put it in the jaws because both sides move the same distance so there is no racking of the jaws. I put a slight bow in the middle to help with pressure as there is some give to the middle. I did use it to drill the aluminum square tubing for the insert and it held with out any problems.
    Thanks Greg
  7. #47
    Sep 2009
    I mounted height gage and included a couple of 5" X 6" X 60" legs clamped in vise to see if it would clamp at both ends.
    Greg
  8. #48
    Sep 2009
    I finally have some time to work on router. Need to get rails mounted for router head. Will try and get some pictures tonight.
  9. #49
    Sep 2009
    Building stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  10. #50
    Sep 2009
    I need some adjustment on columns so I'm using set screws between plates to give some fine adjustment if I need it. I don't know if this is to smart but welding tends to warp so I'll see.
    Sent from my iPad using Tapatalk
  11. #51
    Jul 2007
    Awesome job on the vice. I've set my router up to allow me to machine vertical pieces, but it's no where near this slick.
  12. #52
    Sep 2009
    Thanks.
    I wanted to try and make it as versatile as possible and being able to remove vise section will allow large pieces to stand vertically.
  13. #53
    Member hanermo's Avatar
    Aug 2004
    barcelona
    Well done.
    Unusual approach and materials, nice craftsmanship, nice pics.
    10/10.
    Thanks for sharing.
    Great vice.
  14. #54
    Sep 2009
    My back ground is in matenance so I have learned to do a lot with very little and just dumb enough to try it. All the stainless is from scrape machines I salvaged. I have been stock piling material for years to build my mill and router. The company I worked for only used stainless steel so I learned to weld and machine parts out of salvage stainless. The design is based around all the possible uses I could come up with as well as materials I have laying around. I have been watching builds on here for a long time and incorporated a lot of design ideas into this build. I also like the no rust factor.
  15. #55
    Feb 2005
    That Clamp is brilliant!
  16. #56
    Sep 2009
    Thanks for the kind words
    I need to get racks order from CNCRouterParts. I can't say enough good thinks about these guys.
  17. #57
    Sep 2009
    I got head welded and mounted to plates
  18. #58
    Sep 2009
  19. #59
    Sep 2009
  20. #60
    Sep 2009
    I started straightening rails today. This is what it looks like with table end down.
