New Machine Build Building stainless steel router - Page 2
Page 2 of 6 FirstFirst 12345 ... LastLast
Results 21 to 40 of 110
Thread: Building stainless steel router
  1. #21
    Sep 2009
    Default Re: Building stainless steel router
    Got the linear actuators working today.Building stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  2. #22
    Sep 2009
    Here is the head I need to mount. I started to look at dust collector and made list of what I want it to do.
    1. Don't want the bit covered so I can see what going on and changing bits.
    2. Want to set height automatically
    3. Would like to blow chips away from cutter while cutting
    I'm sure somebody has already done this but need to make it work on my head.
  3. #23
    Sep 2009
  4. #24
    Sep 2009
  5. #25
    Sep 2009
    Started screwing down deck. I ran short of 80/20 Building stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgand had to order more material it came in today. Now I can start leveling the deck so I can get side rails mounted
  6. #26
    Sep 2009
    After reading about problems not connecting two steppers together and racking Z I've decided to tie the two steppers together. I picked up some black pipe and will weld plugs in ends. I will try and get some picture posted.Building stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  7. #27
    Sep 2009
    Got pulleys bored need to key shaft and pulleys. Laying out motor and bearing plates.Building stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  8. #28
    Sep 2009
    Hi Justin,
    I hope this picture help you with how I bolted 80/20 together. If I can help with anything don't hesitate to let me know.Building stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  9. #29
    Gold Member LeeWay's Avatar
    Jun 2004
    I have used a small hole saw for the same thing, but it did not turn out as nice. Nice job and tools.
    The same thing can be used if you ever use carriage bolts instead of Tnuts and forget to install all the bolts before final assembly.
    Lee
  10. #30
    Sep 2009
    Thanks for the kind words! The pilot keeps the cutter from wandering around. I didn't want to buy a special cutter for this one job so that is why I made. It actually worked better than I had hoped. I don't know how this router will turn out but it's been fun building it so far.
  11. #31
    Jun 2015
    I was actually wondering how you bolted the extrusions for the t-slot table top. I think you are showing pictures of how you assembled the frame extrusions. I am interested in how you secured the table top extrusions. It looks like you have used some flat head bolts that are flush with the surface of the table top extrusions. Please elaborate on that for me. Thanks.
  12. #32
    Sep 2009
    I used 1/4-20x2" countersink Allen screws with 1/8" X 1/2" roll pins. Building stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  13. #33
    Jun 2015
    What did you use to drill/countersink the holes for these screws?
  14. #34
    Sep 2009
    I used 1/4" bit to go thru 3/4" top extrusion and a #7 for threaded bottom for a 1/4-20 tap. And countersink.Building stainless steel router-image-jpeg
  15. #35
    Jun 2015
    Awesome. Thanks for the info.
    Justin
  16. #36
    Sep 2009
    Your more than welcome.
    Greg
    Sent from my iPad using Tapatalk
  17. #37
    Sep 2009
    I finished putting wood on vise jaws today. Here are some pictures
    Thanks GregBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpgBuilding stainless steel router-image-jpg
  18. #38
    Jun 2004
    For machining vertical stock? Very cool. I have an area at the front of my router that I will be doing a similar thing, but much smaller scale. I like the vise approach.
    Lee
  19. #39
    Sep 2009
    I'm going to make an insert out of 80/20 to go in the vise to match the top when I'm not using the vise. I'm really impressed with how much pressure that the vise can applies and it doesn't rack. My bolts for the insert finally showed up so I should be able to finish it.
    Thanks Greg
  20. #40
    Jan 2008
    Very nice
