New Machine Build Skuba Router - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 113
Thread: Skuba Router
  1. #41
    Jun 2012
    Default Re: Skuba Router
    With shipping I'm into each axis motor and driver probably about 1600 or so dollars. Hard to Calc as I got my hiwin rails, bearings and ballscrews on same order
    Yes it's been fun so far. Learned a whole lot. First thing I have learned is that eyes are deceiving. I kept telling myself this was a smaller build because I had so many hours designing it on a computer screen. Didn't really think much about it until I received parts and frame came together. It's a beast! Had a family vacation so I should be back to it next week. Hoping to be making chips by end of November.
    Thank you for the great comments I have also received on this post!
    Sent from my SM-N910V using Tapatalk
  2. #42
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    How big are those motors? That's a lot of money for a single motor and drive.
    You can get 750W AC servos for half that, and 1.5Kw for about $1000. (Chinese)
    Leadshine AC Servo Motor & Drive Sets (220/230 VAC Input)
    UCCNC 2017 Screenset
  3. #43
    Jun 2012
    That was for 4 sets. All 4 are 750w.
  4. #44
    Jun 2012
    My post was after probably 15 miles of walking at Disneyland on a Saturday! Definitely a typo
  5. #45
    May 2014
    That's a pretty good price for what they spin at. I was checking out teknik servos and they are similarly priced it looks like:
    https://www.teknic.com/products/clea...izard/results/
    resolution might be different though
  6. #46
    Jun 2012
    I looked at them as well. Look like a great system. I just got a killer deal when I ordered everything as a packaged deal. I got probably 50 percent of my machine from 1 vendor. Then the other electronics I got from Arturo. All in all I think this build is about 6k in parts. All the machining is free and the extrusion was free. I think if I went any other route I would have broke 10k on this build
  7. #47
    Jun 2012
    Ger....I'm wondering if you have a portrait version of your screenset ever since I saw some stuff on datron, kinda fell in love with the portrait screen versus landscape
  8. #48
    Mar 2003
    Shelby Township
    no, sorry.
  9. #49
    Jun 2012
    Ok so I've taken somewhat of a break. Switched jobs to be closer to home. Saving like 12 hours a week of sitting in traffic. Now I'm 5 min away!!
    So I got the x axis machined out and starting to pre fit parts at the moment. Almost done with the machine base and electrical and will have this fully built probably in 30 days
    Attached Thumbnails Attached Thumbnails Skuba Router-uploadfromtaptalk1450408731724-jpg
  10. #50
    Jun 2012
    Skuba Router-uploadfromtaptalk1450409362185-jpg
  11. #51
    Dec 2014
    Any updates? Is this machine alive yet? Still interested to hear about the Chinese servos.
  12. #52
    Jun 2012
    Machine is coming together! Been a rough winter. My dad got diagnosed with some serious cancer so haven't had all the time to spend on it . Making headway now. Moved the machine up to its permanent home, cut the granite slabs and most of the parts are machined and ready for assembly. So far she is a little over 1000 lbs of steel frame and granite epoxy work table.
    This weekend I'm going to use a catalyzed bed liner material over the machine to take a little of the resonance out of the steel. Tested on some smaller pieces and works like a charm! With the granite in place you can smack with a hammer and hear not resonance in the steel!
    Skuba Router-uploadfromtaptalk1453915129571-jpgSkuba Router-uploadfromtaptalk1453915141469-jpgSkuba Router-uploadfromtaptalk1453915149788-jpgSkuba Router-uploadfromtaptalk1453915172075-jpg
  13. #53
    Jun 2012
    Oh on the granite, we are having 2 identically cut pieces sandwiched together with epoxy. The slab sits on a square steel frame and bolted into place. The the steel square has adjusters for fine tuning height etc which are then bolted down snug with 3/4 inch bolts. Total granite is about 400 lbs and 2.75 thick using the most dense material the granite shops can get their hands on
  14. #54
    May 2005
    Sorry to hear about your father. It is a hard thing to deal with, my father first got sick when I was in the first grade. It was a very slow decline after that.
    Quote Originally Posted by skubajon View Post
    Interesting is the granite supplier doing that for you?
    Pictures are always nice. If you don't mind my asking how much is the granite setting you back? Just wondering about the feasibility of this cost wise vs trying to do an epoxy granite pour.
  15. #55
    Jun 2012
    Thank you for your kind comments. It's tough but hoping this chemo stuff will kick it in the ass
    On the slabs I got lucky as my brother in law works for a granite shop. I was able to get 2 remnants for nothing and got lucky but it could have sent me back 3 or 400 I guess. He cut for free and then we will sandwich together ourselves. One slab was an ugly brown color but the other was a nice grey piece which happened to be the high density stuff. Apparently solid black is the most dense material
    I'll take some pics as we get mounted to the machine. Right now the slabs are stacked against my wall while I urethane coat the steel structure this weekend
  16. #56
    Jun 2012
    I don't know if you can compete with your own pour price wise. Maybe but good resin is expensive like west systems stuff. The nice part though is putting your inserts in before the pour where I have to drill with Diamond bit, 180 holes, and then use structural 2 part adhesive to set them which is like 50 a tube
  17. #57
    Jun 2012
    Wizard. If you want to get some material, you should call around to your local granite shops. They usually have a stack of stuff too small to make a full size countertop with. That's where mine came from and it was like 46x 60 on one piece and 50 x 60 for the other.
  18. #58
    Jun 2012
    A little moc upSkuba Router-uploadfromtaptalk1454119779303-jpg
  19. #59
    Jun 2012
    Skuba Router-uploadfromtaptalk1454294305044-jpg
  20. #60
    Jun 2012
    So running into a little issue here and that is the nuts to hold the linear rails down. These rails take m5 bolts and seem to flex when tightening down by hand. I'm hoping maybe by putting some washers in place that will help the nuts not to bend in the tslot and allow me to apply ample torque.
    Anyone have any other suggestions?
Skuba Router
Skuba Router
