Importing costs nothing.
I get 40 shipments per year from all over the world.
(But mexico is somewhat of a special case, from experience).
Ganadero:
Building the router is easy.
Loot at a mechmate for inspiration, and use linear guides and ac brushless servos.
20 mm hiwin guides are == 400 / axis x 3=1200,
servos 290 x 3 = 1200,
add ethernet pokeys+cnc for hardware pulse generator / interface, 150,
psu 150, done.
25 mm D(iameter) ballscrews for 1200 mm length, 40 mm for 3 m, about 300 each.
Above prices are approximate costs, to you, in mexico, via dhl.
They are the same prices I get here, with 22% IVA tax.
For the 22% you can have them shipped to you in mexico via dhl.
The above will make an industrial quality router good for running professional work all day every day.
Accuracy will be about 0.005 mm on mechanicals.
Weld up frame, make top frame so a single steel member is bolted onto it, below.
Steel member about 40x60x1200 mm for a 1200 mm length.
Have bolted members milled flat by someone with a Haas VF3 or bigger, drilled and tapped for linear guides, about 300 (takes one hour, max).
Bolt trucks below, so the dust does not go onto the rails, trucks.
If you cant find someone, call Hitech mexico, and ask for a customer of theirs near you.
They are the Haas distributors, really nice guys, I know them.
HITEC CNC | M
