I understand the problem of backlash and binding, I know that the obvious solution would be to go with a spring loaded module, but I am just trying to find a simple design, without cutting too much on precision. I read the myths they on the link you provided
They do say that forcing the pinion against the rack does not solve the issue. When I thought of this solution, I imagined it as a simpler version the spring loaded mouths they usually use. IMHO, the only difference with my idea and the spring loaded version is that SL can adjust to the racks being not perfectly parallel, but as the link said, it can happen that the spring doesn't even move.
As for the gear reduction transmission, I totally agree with you ger21, I will include one in the model.
Anyone interested to come up with a smart simple design for that R&P drive ? Somehow in the philosophy of the rest of the model
And as for the plasma build, I do not see any springs on the drives, do you ? Though it is a plasma cutter, so forces applied to the moving parts are constant, most likely no binding problem (correct me if I'm wrong). backlash is still an issus I suppose, but maybe not as big as with a router ?
