OK here are some details:
- The outer extrusions of the base are 40x80mm heavy type aluminum. The extrusions inside the base are 40x80mm light type but same.
- The front and rear walls of the base are 12mm thick 6061 aluminum.
- Profiles on the Y are 40x120mm aluminum extrusion. One is placed vertical and other is horizontal.
- I'll take apart my current router to use the electronics and linear stuff which are:
- 4 x Nema23 motors (I'd like to replace them with servos in the future)
- 15mm linear rail and blocks on X and Y axis
- 12mm THK linear rail and blocks on the Z
- I'll keep using my homemade control box (pic attached).
