I PM'd another member with no problems.
so you are saying with my large and heavy gantry it would be best to wire the power supplies with 220 to prevent overloads and tripping of the breaker? That is no issue just trying to save myself some extra wiring.
I am running a 2.2KW router which will have its own power source, separate from the control cabinet.
I will ask about the use of a inline fuse and if there are internal fuses in each drive.
Thanks for the help
