Yesterday, I installed a new cable management system for the X axis.. Was tired of broken vacuum hoses... Finally broke down and bought a cable chain, and built a mounting system and supports for it all.. Got a couple more things to do (redo the little block where the chain attaches to the gantry so it can't work loose over time, and install side barriers for the cable chain as it wants to walk a little) and then the problems associated with how I had it before should be resolved once and for all... General wiring looks better now too..
